Home » Modeling » GMF (Graphical Modeling Framework) » Custom line routing (Extend rectilinear?)
Custom line routing (Extend rectilinear?) [message #176446] Fri, 07 March 2008 08:20
Hi all, I have a basic GMF generated plugin that contains a lot of states
(each containing event handlers which contain actions). The event
handlers have edges to other states and actions can have multiple edges to
event handlers.
Anyways, my problem exists when the data model contains a ton of states
and event handlers with lots of edges - the edges become hard to follow.
I customized them to be 'rectilinear' by default and created a custom
'anchor' to place the source target where it looks nicer.
However, is it possible to configure/customize the line routing alogrithm?
For example, not to have the edges overlap other edges, or not to overlap
particular nodes, or to first go out the side of a node and not down
through it...
Help much appreciated...cheers.
Previous Topic:Some connection problems
Next Topic:Out of memory when saving Image
Current Time: Mon Jul 14 08:43:17 EDT 2025
Powered by FUDForum. Page generated in 0.08136 seconds
