Where does logger output go? [message #176300] |
Mon, 10 July 2006 17:18  |
When I preview this in the Report Designer, where does the "logger"
output go? I've looked in the console and the following directory:
$ECLIPSE$\plugins\org.eclipse.birt.report.viewer_2.1.0.N2006 0628-1351\birt\logs
function beforeDrawDataPoint(dataPointHints, fill, isce){
logger = isce.getLogger();
val = dataPointHints.getOrthogonalValue();
logger.log(1, "val is " + val);
Re: Where does logger output go? [message #176471 is a reply to message #176343] |
Tue, 11 July 2006 08:44  |
According to the comments in the web.xml, the BIRT_VIEWER_LOG_DIR value
should be left empty to go to the default directory. I set the
BIRT_VIEWER_LOG_LEVEL to FINE.
When I preview the report in the Report Designer, I get a lot of
messages but none from the following code snippet:
seriesText = dataPointHints.getSeriesDisplayValue()
logger.log(1, "Series = " + seriesText)
Jason Weathersby wrote:
> Did you look at setting these two entries:
> <context-param>
> <param-name>BIRT_VIEWER_LOG_DIR</param-name>
> <param-value>FINE</param-value>
> </context-param>
> <!-- Report engine log level -->
> <context-param>
> <param-name>BIRT_VIEWER_LOG_LEVEL</param-name>
> <param-value>ON</param-value>
> </context-param>
> in
> \plugins\org.eclipse.birt.report.viewer_2.1.0.N20060628-1351 \birt\WEB-INF\web.xml
> The log should be showing up in:
> \plugins\org.eclipse.birt.report.viewer_2.1.0.N20060628-1351 \birt\logs
> Jason
> "George Handin" <eclipse@dafunks.com> wrote in message
> news:e8ug6n$jmb$1@utils.eclipse.org...
>> When I preview this in the Report Designer, where does the "logger" output
FUDForum. Page generated in 0.08706 seconds
