Home » Modeling » TMF (Xtext) » [TCS] TCS and UML profiles
[TCS] TCS and UML profiles [message #16660] Thu, 17 July 2008 05:08 Go to next message
I'm really interested by the TCS capabilities, jointly used with ATL.
In our case, we have decided to use a UML profile to give a graphical
concrete syntax to our DSL, using the Papyrus customization capabilities
to rapidly have a dedicated editor.
We'd like to also associate a textual concrete syntax to this DSL , and we
were wondering if TCS would be able to directly associate this syntax to
the UML+Profile metamodel.
The other solution I see is to use an intermediate DSL meta-model with a
transfo from this one to the UML+Profile, but this solution will imply
bigger efforts when the metamodel of our DSL will evolve.
Would you see any other solution?
Thanks for you help,
Sebastien
Re: [TCS] TCS and UML profiles [message #18143 is a reply to message #16660] Wed, 23 July 2008 10:50 Go to previous messageGo to next message
Hi Sébastien,
> we were wondering if TCS would be able to directly associate this syntax
> to the UML+Profile metamodel.
With TCS you can define textual syntaxes for specific metamodels.
In case you have a DSL that is not defined as a metamodel but by another
mechanism (e.g., a UML profile) you need to create a metamodel
representation of your DSL. This corresponds to the "other solution"
that you have identified.
In any case, it may be necessary to deal with evolution:
- updating the TCS model when the metamodel evolves,
- updating the metamodel when the DSL definition evolves,
- etc.
I would recommend using transformations to automate most of these
problems. This may for instance be a transformation to automatically
create the metamodel from the DSL definition (e.g., UML profile).
Note that it may be easier to transform a metamodel into a UML profile
than the reverse operation. Therefore, you may prefer to define a
transformation from the metamodel to the profile.
I personally like this solution because you have a simple representation
of your DSL as a metamodel (abstract syntax) plus the definitions of two
concrete syntaxes:
- Graphical, using a transformation to a UML profile,
- Textual, using a TCS model.
Frédéric Jouault
Re: [TCS] TCS and UML profiles [message #18280 is a reply to message #18143] Thu, 24 July 2008 11:29 Go to previous messageGo to next message
Hi Frederic, and thanks for your answer!
It confirms the idea I had.
However I was wondering if the "static profile" mechanism could be used.
It externalizes the ecore meta-model normally included in the UML profile
and permits to consider stereotyped elements as instances of this
meta-model.
(This mecanism is used in the latest version of Papyrus for the
customization).
But I don't know exactly how it works, I have to investigate more...
Thanks again for all the nice work you do,
Sebastien
Re: [TCS] TCS and UML profiles [message #18297 is a reply to message #18280] Fri, 25 July 2008 09:48 Go to previous message
Hi Sébastien,
> profile and permits to consider stereotyped elements as instances of
> this meta-model.
> customization).
This is an interesting issue. Please let us know the results of your
investigation :-).
You're welcome, and thanks.
Frédéric Jouault
Previous Topic:Mode, Deep and WordRule
Next Topic:[TCS] operatorTemplate source list containment
Current Time: Sat Jun 07 15:02:06 EDT 2025
Powered by FUDForum. Page generated in 0.03007 seconds
