Home » Archived » Albireo » More tips for the sample code
More tips for the sample code [message #1401] Wed, 26 September 2007 15:44 Go to next message
Originally posted by: canadianguy.gmail.com
I have found several more issues relating to focus and the SWT/Swing
integration. I have breifly outlined each issue below and posted my code
modifications at the bottom. I suspect I may not be clear enough in
describing both the issues, the solutions, and how they work, so please ask
any questions you might have. I would imagine others have periodically
noticed at least some of these issues as well.
Any thoughts on these Gordon?
My workarounds affect EmbeddedSwingComposite, SwtFocusHandler, and
AwtFocusHandler classes.
The issues:
#1
When using keyboard navigation, the default code misses sending the focus to
the AWT control on its first pass through (the returned focus component is
null). This can be solved by setting awtHasFocus to true at the top of the
gainFocus method instead of at the bottom. This will ensure that an attempt
is made to find a focusable swing control on the first focus attempt.
#2
I use an EmbeddedSwingComponent as the full contents of an editor
(consequently, the IWorkbenchPart's setFocus method sets the focus to the
EmbeddedSwingComponent). When issue #1 is fixed (ie, the AWT control
automatically gets the focus when the SWT control gets the focus), there is
occasionally a deadlock in Java 1.6 when several editors are opened at once
(even though only asycExec and invokeLater calls are used). The deadlock is
happening way down in AWT Code in the WPanelPeer class and is triggered by
the component.requestFocus inside of the awtHandler's gainFocus method.
This seems to be solved when issue #3 is solved.
#3
When the EmbeddedSwingComponent is the only focusable component inside of a
Tab Folder, the awtHandler.gainFocus call causes a malfunction in keyboard
navigation. When the tab labels get the focus (a tab's label is
underlined), typically one can switch between tabs by using the arrow keys
and then dive into the current tab using the 'tab' key. To do this, the SWT
Tab Folder seems to momentarily set the focus to the tab's contents and then
return focus to the tab label.
The problem is that we are telling AWT to take the focus when the tab's
contents gets the focus, so the focus doesn't go back to tab's label. I
have added set/get AbortFocus methods to the SwtFocusHandler. The abort
focus value is set whenever the SWT Control's focus is gained or lost. This
way if the SWT control loses focus before AWT has a chance to set its focus
we can decide not to set the AWT focus.
I suspect the deadlock also has something to do with this quick transfer of
focus.
#4
There is a memory leak when you dispose of the SWT Control even if you set
the frame to null. This leak is present in Java 1.5 update 11 and Java 1.6.
To remove the memory leak, the frame needs to have its FocusableWindowState
set to false and it should be disposed of when the EmbeddedSwingComponent is
disposed of. The frame should be disposed of in the Swing EDT.
In EmbeddedSwingComposite:
public EmbeddedSwingComposite(Composite parent, int style) {
super(parent, style | SWT.EMBEDDED | SWT.NO_BACKGROUND);
getDisplay().addListener(SWT.Settings, settingsListener);
setLayout(new FillLayout());
this.addDisposeListener(new DisposeListener()
public void widgetDisposed(DisposeEvent e)
final Frame frame = getFrame();
Runnable disposeEDTRunnable = new Runnable()
public void run()
disposeInEDT(frame);
if (SwingUtilities.isEventDispatchThread())
disposeEDTRunnable.run();
else
SwingUtilities.invokeLater(disposeEDTRunnable);
currentSystemFont = getFont();
private boolean awtDisposed = false;
public void disposeInEDT(Frame frame)
if (!awtDisposed)
awtDisposed = true;
if (frame != null)
frame.setFocusableWindowState(false);
frame.setFocusable(false);
frame.setEnabled(false);
getRootPaneContainer().getRootPane().getContentPane().remove All();
frame.removeAll();
frame.dispose();
A summary of my code changes below:
In AwtFocusHandler
public void gainFocus() {
assert frame != null;
// assert !awtHasFocus;
assert EventQueue.isDispatchThread(); // On AWT event thread
if (getSwtHandler().getAbortFocus())
awtHasFocus = false;
return;
awtHasFocus = true;
In SwtFocusHandler:
public void focusGained(FocusEvent e)
assert awtHandler != null;
assert Display.getCurrent() != null; // On SWT event thread
setAbortFocus(false);
System.out.println("Gained: " + e.toString() + " (" +
e.widget.getClass().getName() + ")");
EventQueue.invokeLater(new Runnable() {
public void run() {
System.out.println("Gain Focus - SWT Focus Handler EDT");
awtHandler.gainFocus();
private volatile boolean abortFocus = false;
public boolean getAbortFocus()
return abortFocus;
public void setAbortFocus(boolean abort)
this.abortFocus = abort;
public void focusLost(FocusEvent e)
setAbortFocus(true);/*
System.out.print("Focus Control: ");
System.out.println(e.display.getFocusControl());
System.out.println("Lost: " + e.toString() + " (" +
e.widget.getClass().getName() + ")");*/
One more issue [message #1407 is a reply to message #1401] Wed, 26 September 2007 16:24 Go to previous messageGo to next message
This also has to do with putting the EmbeddedSwingComposite under a tab
folder.
When AWT has focus and the tab is clicked, AWT loses focus but the composite
does not get a focusGained event (as far as SWT is concerned, it never lost
focus).
I have added a check when the AWT window loses focus to inform the SWT
handler that the backing composite may have re-gained the focus.
At the end of AwtFocusHandler.windowLostFocus:
if (!swtHandler.getDisplay().isDisposed())
Runnable runnable = new Runnable()
public void run()
swtHandler.reApplyFocus();
swtHandler.getDisplay().asyncExec(runnable);
In SwtFocusHandler:
public void reApplyFocus()
if (Display.getCurrent() != null &&
!Display.getCurrent().isDisposed() && composite ==
Display.getCurrent().getFocusControl())
// System.out.println("Gained: " + e.toString() + " (" +
public void run() {
// System.out.println("Gain Focus - SWT Focus Handler
EDT");
Re: More tips for the sample code [message #1412 is a reply to message #1401] Thu, 27 September 2007 16:50 Go to previous messageGo to next message
James, first of all, thank you for sharing your fixes and improvements.
I have some comments and questions below.
> The issues:
> #1
Yes, this is definitely a bug in the article. Another solution is to
change the EmbeddedChildFocusTraversalPolicy.getCurrentComponent()
method to call super.getDefaultComponent, rather than
this.getDefaultComponent.
> #2
It's now pretty clear that Component.requestFocus has to be used
carefully to avoid deadlock (and in our case other problems). The main
thing is to make sure that it is always called from the AWT event
thread. Unfortunately, the article code calls it from the SWT thread in
two places. For example, I've now re-implemented
EmbeddedSwingComposite.setFocus() as follows:
public boolean setFocus() {
checkWidget();
//if (!isFocusable()) {
// return false;
if (swtHandler != null) {
// Setting focus on the embedded component must posted to the
// AWT thread because:
// 1) The AWT Component.requestFocus method can deadlock if
// called simultaneously from different threads.
// 2) The embedded component is created asynhronously (on the
// AWT thread), so it may not exist yet.
// The call below does the appropriate posting. Since it is
done
// asynchronously, it is impossible to know the result, so
// always return true.
swtHandler.transferFocusToAwt();
return true;
} else {
return super.setFocus();
transferFocusToAwt is what you would expect:
void transferFocusToAwt() {
public void run() {
A similar change is needed to the EmbeddedSwingComposite.forceFocus method.
I suspect these fixes will eliminate the deadlock problem you saw and
that your solution to #3, though useful in its own right, simply made
the deadlock less likely.
> #3
> focus.
I didn't know you could navigate this way, so it clearly wasn't tested
:-). Your solution looks like a good one.
> #4
Interesting. SWT_AWT.new_Frame() installs a listener that is supposed to
dispose the frame (on the AWT event thread) when the composite is
disposed. Any ideas on why this is not happening?
Is the need to set FocusableWindowState to false maybe due to this bug?
http://bugs.sun.com/bugdatabase/view_bug.do?bug_id=6469530.
Or something else? I'm wondering if there's something that needs to be
reported to Sun...
I ran into a similar leak that was triggered by adding components to the
frame from outside the AWT EDT. See
http://bugs.sun.com/bugdatabase/view_bug.do?bug_id=6411042.
Re: One more issue [message #1416 is a reply to message #1407] Thu, 27 September 2007 17:20 Go to previous messageGo to next message
James,
Excellent, thanks! I had noticed this problem, but my attempted solution
had bad side effects. You can still find it (partially) in the
commented-out code. I think you are doing a better job of using the
right thread in all cases, so that may be what avoids the side effects.
As I recall, the problem with my attempt was that the AWT frame would
grab focus in cases where it shouldn't. For example, if I tried to
activate a different application's window, suddenly the RCP app with the
embedded AWT frame would pop up on top of it. I assume you haven't seen
anything like this with your fix?
> folder.
> focus).
> public void run()
> In SwtFocusHandler:
> public void run() {
> EDT");
Re: More tips for the sample code [message #1420 is a reply to message #1401] Thu, 27 September 2007 17:25 Go to previous messageGo to next message
James wrote:
> #4
One other thing I forgot to mention... in the article, I had an
implementation of EmbeddedSwingComposite.dispose like this:
public void dispose() {
if (!isDisposed()) {
getDisplay().removeListener(SWT.Settings, settingsListener);
getDisplay().removeFilter(SWT.Show, menuListener);
super.dispose();
This is the wrong way to write code that runs at dispose time. The two
listeners should be removed in a dispose listener, just like the one
you've created here, so you should add them to your widgetDisposed() and
remove the dispose() method.
> public void run()
> else
Re: One more issue [message #1424 is a reply to message #1416] Fri, 28 September 2007 07:33 Go to previous messageGo to next message
Gordon,
I haven't seen anything like that but that doesn't guarantee that it won't
happen in a kind of 'perfect storm' of the two UI Threads. When the RCP
application loses focus to another application, this causes the SWT's focus
component to become null, so the AWT component shouldn't re-grab the focus.
-James
"Gordon Hirsch" <gordon.hirsch@sas.com> wrote in message
news:fdh6qi$v82$1@build.eclipse.org...
> James,
> > folder.
composite
lost
> > focus).
> > public void run()
> > In SwtFocusHandler:
> > public void run() {
Handler
> > EDT");
Re: More tips for the sample code [message #1428 is a reply to message #1420] Fri, 28 September 2007 07:40 Go to previous messageGo to next message
I thought that was the case (I noticed that the dispose code wasn't getting
called). I have already moved the dispose code elsewhere and call it from
the dispose listener.
news:fdh750$un$1@build.eclipse.org...
> James wrote:
> > #4
set
1.6.
> super.dispose();
> > public void run()
> > else
Re: More tips for the sample code [message #1432 is a reply to message #1412] Fri, 28 September 2007 07:54 Go to previous messageGo to next message
news:fdh53e$j7i$1@build.eclipse.org...
code
ask
Not a problem. Your article code allowed us to have a product that was at
least usable (I was going crazy dealing with modal dialogs). We all benefit
from making these two UIs play well together.
> > The issues:
> > #1
focus to
is
the
attempt
> > #2
the
is
once
deadlock is
by
In my version of the article code (I'm not sure it changed after I
downloaded it), the setFocus doesn't make any AWT Calls. It simple checks
to see if it is focusable and calls super.setFocus()... strange.
> checkWidget();
> // return false;
> done
> return true;
> } else {
> public void run() {
method.
> > #3
of a
keyboard
keys
SWT
then
This
focus
of
> > focus.
> > #4
set
1.6.
Yes, I'm pretty sure that this is the same bug (as I recall from the last
time I ran this through a profiler). The GlobalRef stays in place until
another component gets focus. In our case (probably some of the special
world of the SWT/AWT mix), it is reproducable 100% of the time. I have
found that setting the setFocusableWindowState to false before the frame is
disposed is also a work-around to the problem. To be honest, I don't know
if the other explicit call to dispose is necessary.
> reported to Sun...
Re: More tips for the sample code [message #1435 is a reply to message #1432] Fri, 28 September 2007 08:05 Go to previous messageGo to next message
Aside from not seeming to make an AWT call out side of the AWT Thread, this
alternate implementation you have proposed breaks the fix for keyboard
navigation I describe (the SWT Component never really gains focus so it can
never lose it).
> > checkWidget();
> > // return false;
the
the
> > done
> > return true;
> > } else {
> > public void run() {
> method.
Re: More tips for the sample code [message #3240 is a reply to message #1435] Sun, 07 October 2007 14:10 Go to previous messageGo to next message
> never lose it).
You're right. After looking a little closer, I don't think the
implementations of setFocus/forceFocus are necessary at all.
By the way, the extra code in setFocus/forceFocus was not part of the
original article. Sorry for any confusion I might have caused.
>>> checkWidget();
>>> // return false;
> the
> the
>>> done
>>> return true;
>>> } else {
>>> public void run() {
>> method.
Re: More tips for the sample code [message #5247 is a reply to message #1412] Mon, 26 November 2007 21:35 Go to previous messageGo to next message
Gordon (or anyone),
As you suspected, my workaround for the requestFocus deadlock issue is not a
solution 100% of the time. In fact, lately the issue is happening
frequently enough to prevent my next software release.
Have you any idea why I might be getting deadlock in
WComponentPeer._requestFocus when calling it from the AWT EDT after an
invokeLater from the SWT EDT? I could really use some help with this one.
Naturally, as with most timing bugs, I don't really have a snipped that I
can post.
-James
>> ask
> James, first of all, thank you for sharing your fixes and improvements. I
>> The issues:
>> #1
>> to
>> is
>> the
>> attempt
> change the EmbeddedChildFocusTraversalPolicy.getCurrentComponent() method
> to call super.getDefaultComponent, rather than this.getDefaultComponent.
>> #2
>> is
>> once
>> is
>> by
> It's now pretty clear that Component.requestFocus has to be used carefully
> to avoid deadlock (and in our case other problems). The main thing is to
> make sure that it is always called from the AWT event thread.
> Unfortunately, the article code calls it from the SWT thread in two
> checkWidget();
> // return false;
> done
> return true;
> } else {
> public void run() {
> method.
> I suspect these fixes will eliminate the deadlock problem you saw and that
> your solution to #3, though useful in its own right, simply made the
>> #3
>> a
>> keyboard
>> keys
>> SWT
>> then
>> This
>> focus
>> of
>> focus.
>> #4
>> set
>> 1.6.
>> is
> reported to Sun...
Re: More tips for the sample code [message #5313 is a reply to message #5247] Tue, 27 November 2007 11:19 Go to previous messageGo to next message
James Peltzer wrote:
> Gordon (or anyone),
> can post.
Could you post stack traces from the deadlocked JVM? They would be
extremely helpful in diagnosing what the two EDTs (and possibly other
threads) are doing at that point.
Re: More tips for the sample code [message #5368 is a reply to message #5313] Tue, 27 November 2007 18:31 Go to previous messageGo to next message
Unfortunately I seem the Debugger seems to throw errors whenever I try to
suspend execution. I have changed my Eclipse version from 3.2.2 to 3.3.1.1
and the issue has gone back into hiding. I'll try to get more information
to you.
-James
news:fihg2f$rkr$1@build.eclipse.org...
>> Gordon (or anyone),
>> not a solution 100% of the time. In fact, lately the issue is happening
>> one. Naturally, as with most timing bugs, I don't really have a snipped
>> that I can post.
Re: More tips for the sample code [message #6694 is a reply to message #5368] Wed, 28 November 2007 11:31 Go to previous messageGo to next message
You can also get the stack traces with the jconsole tool that comes with
the JDK
( http://java.sun.com/j2se/1.5.0/docs/guide/management/jconsol e.html) or
by hitting Ctrl-Break (on Windows, running with java.exe as opposed to
javaw.exe).
> to you.
> -James
>>> Gordon (or anyone),
>>> that I can post.
Re: More tips for the sample code [message #10860 is a reply to message #6694] Fri, 28 November 2008 12:17 Go to previous messageGo to next message
Hi I have similar problem. During invocation of function
JTabbedPane.setSelectedIndex my application hangs.
Here is part of stack trace from jconsole:
State: BLOCKED on java.awt.Component$AWTTreeLock@1cc2f15 owned by:
AWT-EventQueue-0
Total blocked: 9 726 Total waited: 145 509
Stack trace:
java.awt.Component.invalidate(Unknown Source)
java.awt.Container.invalidate(Unknown Source)
javax.swing.JComponent.revalidate(Unknown Source)
javax.swing.plaf.basic.BasicTextUI$RootView.preferenceChange d(Unknown
Source)
javax.swing.text.View.preferenceChanged(Unknown Source)
javax.swing.text.PlainView.updateDamage(Unknown Source)
javax.swing.text.PlainView.insertUpdate(Unknown Source)
javax.swing.plaf.basic.BasicTextUI$RootView.insertUpdate(Unk nown Source)
javax.swing.plaf.basic.BasicTextUI$UpdateHandler.insertUpdat e(Unknown
Source)
javax.swing.text.AbstractDocument.fireInsertUpdate(Unknown Source)
javax.swing.text.AbstractDocument.handleInsertString(Unknown Source)
javax.swing.text.AbstractDocument.insertString(Unknown Source)
javax.swing.text.PlainDocument.insertString(Unknown Source)
javax.swing.JTextArea.append(Unknown Source)
com.sun.deploy.util.ConsoleWindow$25.run(Unknown Source)
java.awt.event.InvocationEvent.dispatch(Unknown Source)
java.awt.EventQueue.dispatchEvent(Unknown Source)
java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
java.awt.EventDispatchThread.pumpEvents(Unknown Source)
java.awt.EventDispatchThread.run(Unknown Source)
State: WAITING on java.lang.Object@180dc21
Total blocked: 31 Total waited: 20 612
Stack trace:
java.lang.Object.wait(Native Method)
java.lang.Object.wait(Object.java:485)
com.sun.deploy.util.ConsoleTraceListener$ConsoleWriterThread .run(Unknown
Source)
State: WAITING on com.sun.deploy.cache.CleanupThread@1887a29
Total blocked: 0 Total waited: 1
Stack trace:
com.sun.deploy.cache.CleanupThread.run(Unknown Source)
State: TIMED_WAITING on javax.swing.TimerQueue@6a2cde
Total blocked: 8 Total waited: 284 784
Stack trace:
javax.swing.TimerQueue.run(Unknown Source)
java.lang.Thread.run(Unknown Source)
State: RUNNABLE
Total blocked: 6 119 Total waited: 721 830
Stack trace:
sun.awt.windows.WComponentPeer._requestFocus(Native Method)
sun.awt.windows.WComponentPeer.requestFocus(Unknown Source)
java.awt.Component.requestFocusHelper(Unknown Source)
java.awt.Component.requestFocus(Unknown Source)
java.awt.Component.postNextFocusHelper(Unknown Source)
java.awt.Component.nextFocusHelper(Unknown Source)
java.awt.Container.nextFocusHelper(Unknown Source)
java.awt.Component.doAutoTransfer(Unknown Source)
java.awt.Component.autoTransferFocus(Unknown Source)
java.awt.Component.hide(Unknown Source)
- locked java.awt.Component$AWTTreeLock@1cc2f15
java.awt.Component.show(Unknown Source)
java.awt.Component.setVisible(Unknown Source)
javax.swing.JComponent.setVisible(Unknown Source)
javax.swing.JTabbedPane.fireStateChanged(Unknown Source)
javax.swing.JTabbedPane$ModelListener.stateChanged(Unknown Source)
javax.swing.DefaultSingleSelectionModel.fireStateChanged(Unk nown Source)
javax.swing.DefaultSingleSelectionModel.setSelectedIndex(Unk nown Source)
javax.swing.JTabbedPane.setSelectedIndexImpl(Unknown Source)
javax.swing.JTabbedPane.setSelectedIndex(Unknown Source)
com.qumak.toolbar.client.mail.gui.MailPanel_Tabs.setSelected LastPanel(MailPanel_Tabs.java:122)
com.qumak.toolbar.client.mail.gui.MailPanel_Controller.prepa reGUIForNewMail(MailPanel_Controller.java:385)
com.qumak.toolbar.client.mail.gui.MailPanel_Incomming$Forwar dMailWorker.done(MailPanel_Incomming.java:300)
javax.swing.SwingWorker$5.run(Unknown Source)
javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.run(Unk nown Source)
sun.swing.AccumulativeRunnable.run(Unknown Source)
javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.actionP erformed(Unknown
Source)
javax.swing.Timer.fireActionPerformed(Unknown Source)
javax.swing.Timer$DoPostEvent.run(Unknown Source)
Last thread is causing the deadlock, but I don't know why. Currently I use
some components built on SWT (3.5 Milestone 1). Also I cannot notice any
swt function invocations in the whole jconsole trace.
I will be very grateful for reply. What do you think?
Jan Gurda
Re: More tips for the sample code [message #10874 is a reply to message #10860] Tue, 02 December 2008 13:20 Go to previous messageGo to next message
This doesn't look like a problem with SWT/Swing integration. What's
unusual is that you seem to have two AWT event threads running and there
is some contention between them. I don't know you'd diagnose/fix this
problem.
> AWT-EventQueue-0
> Stack trace: java.awt.Component.invalidate(Unknown Source)
> Source)
> Source)
> Stack trace: java.lang.Object.wait(Native Method)
> Source)
> State: RUNNABLE
> Stack trace: sun.awt.windows.WComponentPeer._requestFocus(Native Method)
> Source)
> use some components built on SWT (3.5 Milestone 1). Also I cannot notice
> any swt function invocations in the whole jconsole trace.
> Jan Gurda
Re: More tips for the sample code [message #11052 is a reply to message #1412] Tue, 23 June 2009 19:46 Go to previous message
Gordon - has this fix been applied to 0.0.3? I took a look, but it seems
like things have changed a lot and I was not able to identify if these
changes are in the latest release. Or are they no longer even necessary?
Thanks!
- Ken
>> ask
>> The issues:
>> #1
>> to
>> is
>> the
>> attempt
>> #2
>> is
>> once
>> is
>> by
> checkWidget();
> // return false;
> done
> return true;
> } else {
> public void run() {
> method.
>> #3
>> a
>> keyboard
>> keys
>> SWT
>> then
>> This
>> focus
>> of
>> focus.
>> #4
>> set
>> 1.6.
>> is
> reported to Sun...
One more issue [message #572392 is a reply to message #1401] Wed, 26 September 2007 16:24 Go to previous message
folder.
focus).
public void run()
In SwtFocusHandler:
public void run() {
EDT");
Re: More tips for the sample code [message #572420 is a reply to message #1401] Thu, 27 September 2007 16:50 Go to previous message
> The issues:
> #1
> #2
checkWidget();
// return false;
done
return true;
} else {
public void run() {
> #3
> focus.
> #4
reported to Sun...
Re: One more issue [message #572442 is a reply to message #1407] Thu, 27 September 2007 17:20 Go to previous message
James,
> folder.
> focus).
> public void run()
> In SwtFocusHandler:
> public void run() {
> EDT");
Re: More tips for the sample code [message #572456 is a reply to message #1401] Thu, 27 September 2007 17:25 Go to previous message
James wrote:
> #4
super.dispose();
> public void run()
> else
Re: One more issue [message #572494 is a reply to message #1416] Fri, 28 September 2007 07:33 Go to previous message
Gordon,
-James
> James,
> > folder.
composite
lost
> > focus).
> > public void run()
> > In SwtFocusHandler:
> > public void run() {
Handler
> > EDT");
Re: More tips for the sample code [message #572565 is a reply to message #1420] Fri, 28 September 2007 07:40 Go to previous message
> James wrote:
> > #4
set
1.6.
> super.dispose();
> > public void run()
> > else
Re: More tips for the sample code [message #572628 is a reply to message #1412] Fri, 28 September 2007 07:54 Go to previous message
code
ask
> > The issues:
> > #1
focus to
is
the
attempt
> > #2
the
is
once
deadlock is
by
> checkWidget();
> // return false;
> done
> return true;
> } else {
> public void run() {
method.
> > #3
of a
keyboard
keys
SWT
then
This
focus
of
> > focus.
> > #4
set
1.6.
> reported to Sun...
Re: More tips for the sample code [message #572661 is a reply to message #1432] Fri, 28 September 2007 08:05 Go to previous message
never lose it).
> > checkWidget();
> > // return false;
the
the
> > done
> > return true;
> > } else {
> > public void run() {
> method.
Re: More tips for the sample code [message #572762 is a reply to message #1435] Sun, 07 October 2007 14:10 Go to previous message
> never lose it).
>>> checkWidget();
>>> // return false;
> the
> the
>>> done
>>> return true;
>>> } else {
>>> public void run() {
>> method.
Re: More tips for the sample code [message #573612 is a reply to message #1412] Mon, 26 November 2007 21:35 Go to previous message
Gordon (or anyone),
can post.
-James
>> ask
>> The issues:
>> #1
>> to
>> is
>> the
>> attempt
>> #2
>> is
>> once
>> is
>> by
> checkWidget();
> // return false;
> done
> return true;
> } else {
> public void run() {
> method.
>> #3
>> a
>> keyboard
>> keys
>> SWT
>> then
>> This
>> focus
>> of
>> focus.
>> #4
>> set
>> 1.6.
>> is
> reported to Sun...
Re: More tips for the sample code [message #573633 is a reply to message #5247] Tue, 27 November 2007 11:19 Go to previous message
> Gordon (or anyone),
> can post.
Re: More tips for the sample code [message #573664 is a reply to message #5313] Tue, 27 November 2007 18:31 Go to previous message
to you.
-James
>> Gordon (or anyone),
>> that I can post.
Re: More tips for the sample code [message #573684 is a reply to message #5368] Wed, 28 November 2007 11:31 Go to previous message
the JDK
javaw.exe).
> to you.
> -James
>>> Gordon (or anyone),
>>> that I can post.
Re: More tips for the sample code [message #574847 is a reply to message #6694] Fri, 28 November 2008 12:17 Go to previous message
AWT-EventQueue-0
Stack trace:
Source)
Source)
Stack trace:
Source)
Stack trace:
Stack trace:
State: RUNNABLE
Stack trace:
Source)
Jan Gurda
Re: More tips for the sample code [message #574867 is a reply to message #10860] Tue, 02 December 2008 13:20 Go to previous message
problem.
> AWT-EventQueue-0
> Source)
> Source)
> Source)
> State: RUNNABLE
> Source)
> Jan Gurda
Re: More tips for the sample code [message #575209 is a reply to message #1412] Tue, 23 June 2009 19:46 Go to previous message
Thanks!
- Ken
>> ask
>> The issues:
>> #1
>> to
>> is
>> the
>> attempt
>> #2
>> is
>> once
>> is
>> by
> checkWidget();
> // return false;
> done
> return true;
> } else {
> public void run() {
> method.
>> #3
>> a
>> keyboard
>> keys
>> SWT
>> then
>> This
>> focus
>> of
>> focus.
>> #4
>> set
>> 1.6.
>> is
> reported to Sun...
Previous Topic:Restoring the active shell in SwtInputBlocker does not work properly
Next Topic:ctrl-c ctrl-v not working in 3.5
Current Time: Tue Jul 15 00:55:18 EDT 2025
Powered by FUDForum. Page generated in 0.21789 seconds
