Home » Language IDEs » Java Development Tools (JDT) » "The system cannot find the file specified"
"The system cannot find the file specified" [message #175807] Sun, 29 August 2004 15:40 Go to next message
Originally posted by: peng.cs.unt.edu
I have a project 'Test' with 2 files:
1. E:\workspace\test\src\Test.java (code listing see below)
2. E:\workspace\test\src\abc.txt
When I use "Run As Java Application", I got an error message:
"java.io.FileNotFoundException: abc.txt
(The system cannot find the file specified)"
If I move abc.txt to E:\workspace\test\abc.txt, it will succeed.
Could you tell me how to set up Eclipse so that I don't need to move
my resource files (keep them in src folder)?
Thanks.
>>>>>>Here is my Test.java:
import java.io.*;
public class Test {
try {
BufferedReader reader = new BufferedReader(new
FileReader("abc.txt"));
System.out.println(reader.readLine());
} catch (IOException e) {
System.out.println(e);
Re: "The system cannot find the file specified" [message #175898 is a reply to message #175807] Mon, 30 August 2004 10:56 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Do you have src/ marked as a source directory in your java build path?
Thanks, Rich Kulp
Re: "The system cannot find the file specified" [message #175904 is a reply to message #175807] Mon, 30 August 2004 11:01 Go to previous messageGo to next message
Originally posted by: eostroukhov.hotmail.com
My guess is that it uses project folder as a working folder. Open properties
of the launch configuration and on the arguments tab set working directory
to the src folder.
Eugene
"Sean" <peng@cs.unt.edu> wrote in message news:cgtbfu$eol$1@eclipse.org...
> Thanks.
> import java.io.*;
> public class Test {
> public static void main(String[] args) {
> try {
Re: "The system cannot find the file specified" [message #175964 is a reply to message #175904] Mon, 30 August 2004 17:03 Go to previous messageGo to next message
Eugene Ostroukhov and Rich Kulp:
Thank you both for the kindly help.
In this case, Eugene' instructions solve my problem.
Thanks a lot.
I did mark src/ as a source directory in my java build path before.
My Preferences>Java>Build Path has
Source folder name: src
Output folder name: bin
When "Create a Java project", I set
'Project layout' to 'Create separate source and output folders' and
'Source folders on build path:' to test/src and
'Default output folder' to test/bin.
However, I did not set up working directory to the src folder before.
I thought Eclipse could infer that info automatically.
By the way, seting up working directory to the bin/ folder also worked
since Eclipse copied my resource files to the bin/ folder.
As a newbie I spent serveral hours on this issue.
Many thanks to you two.
Sean
> to the src folder.
> Eugene
> > 1. E:workspacetestsrcTest.java (code listing see below)
> > 2. E:workspacetestsrcabc.txt
> > If I move abc.txt to E:workspacetestabc.txt, it will succeed.
> > Thanks.
> > import java.io.*;
> > public class Test {
> > try {
Re: "The system cannot find the file specified" [message #175972 is a reply to message #175964] Mon, 30 August 2004 18:23 Go to previous messageGo to next message
Ah, right. I was thinking it was using the classloader to find the file,
but I forgot File(afilename) uses the working directory, which is
entirely different.
If it was using the classloader, then it needs to be in a source
directory, which then copies it to the bin directory so that the
classloader can find it.
Thanks, Rich Kulp
Re: "The system cannot find the file specified" [message #176123 is a reply to message #175972] Tue, 31 August 2004 10:17 Go to previous message
Rich Kulp:
Thanks.
I have other projects that I have not moved to Eclipse.
They use classloader. You advices will certainly help.
Sean.
Previous Topic:[Bug] "Sort members" ignore dependancies between static variables.
Next Topic:New: how to set up a project with existing files
Current Time: Sat Sep 06 09:50:11 EDT 2025
Powered by FUDForum. Page generated in 0.03922 seconds
