Unrecognized option: -Xdebug [message #16594] |
Wed, 07 May 2003 09:53  |
Originally posted by: forero.media-interactive.de
I am using Eclipse on W2k, with the Sun JDK 1.4.1_02, most off the things
work fantastic; but I am unable to debug a local application.
When I try to go to (Debug > Debug As > Java Application) the perspective is
change to the Debug prespective and appears to be starting the debugging
process, afterwards it shows a dialog box with the message "Can not connect
to VM" and in the Console the messages "Unrecognized option: -Xdebug"
"Could not create the Java virtual machine." are printed.
I will appreciate any help,
regards,
Oscar Forero.
Re: Unrecognized option: -Xdebug [message #16612 is a reply to message #16594] |
Wed, 07 May 2003 10:19  |
Originally posted by: Olivier_Thomann.ca.ibm.comNOSPAM
On Wed, 7 May 2003 15:53:43 +0200, "Oscar Forero"
Check the JRE you are using to debug your application. Are you sure
this is a JDK1.4.1?
-Xdebug is a known option for the JVM 1.4.1.
Olivier
FUDForum. Page generated in 0.06695 seconds
