access to te CVS repo [message #16571] |
Fri, 28 March 2003 09:53 |
Originally posted by: jeff_mcaffer_REMOVE.ca.ibm.com
We have not been clear on the website regarding CVS access. All
dev.eclipse.org repositories have anonymous pserver access. You can go into
Eclipse and create a new repository location (in the CVS repo view) and just
put in
host: dev.eclipse.org
user: anonymous
method: pserver
From there navigate wherever you want and check out the projects desired.
Note that the Equinox web site is in "equinox-home" and the code is in
"org.eclipse.equinox".
The website should be updated with a bit more info on this.
Jeff
FUDForum. Page generated in 0.06977 seconds
