Home » Archived » M2M (model-to-model transformation) » XMI tutorial
XMI tutorial [message #16559] Thu, 15 February 2007 08:30 Go to next message
Originally posted by: walcir.fontanini.cenpra.gov.br
I decided to build some UML "models" by hand (the "metamodels" were done
with KM3 sintax).
Where can I find a good tutorial on building a XMI file from an UML
class diagram ? The UML class "attributes" and "operations" elements are
easy to create, but relationships (composites, generalizations,
unidirectional), abstract classes in the middle and circular navigation
is becoming a problem.
-walcir
Re: XMI tutorial [message #16575 is a reply to message #16559] Thu, 15 February 2007 07:41 Go to previous messageGo to next message
--------------000403010300040209010401
Walcir,
Maybe I'm misunderstanding your questions, but wouldn't it be *far
easier* to use the UML2 project's APIs to create an instance and then
serialize that as XMI?
walcir fontanini wrote:
> done with KM3 sintax).
> are easy to create, but relationships (composites, generalizations,
> navigation is becoming a problem.
> -walcir
<html>
<head>
</head>
Walcir,<br>
<br>
Maybe I'm misunderstanding your questions, but wouldn't it be <b>far
easier</b> to use the UML2 project's APIs to create an instance and
then serialize that as XMI?<br>
<br>
<br>
<blockquote cite="mider1jpv$ej0$1@utils.eclipse.org" type="cite">Hi,
<br>
<br>
<br>
are easy to create, but&nbsp; relationships (composites, generalizations,
&nbsp;&nbsp; is becoming a problem.
<br>
<br>
<br>
-walcir
<br>
</blockquote>
<br>
</body>
</html>
--------------000403010300040209010401--
Re: XMI tutorial [message #16591 is a reply to message #16575] Thu, 15 February 2007 09:13 Go to previous messageGo to next message
Ed,
My main goal is to experiment with the ATL language, and the UML
"models" are just a imple input data.
-walcir
Ed Merks wrote:
> Walcir,
>> Thanks,
>> -walcir
Re: XMI tutorial [message #16605 is a reply to message #16591] Thu, 15 February 2007 08:20 Go to previous messageGo to next message
Walcir,
That doesn't really answer the question. UML is complex and XMI is
complex, so to create a complex serialization of a complex model, by
hand, in order to end up with simple (and correct) input data, seems
like a very complex problem that could be reduced to just a complex
one. I must be misunderstanding some aspect of this...
> Ed,
> -walcir
> Ed Merks wrote:
>> Walcir,
>>> Hi,
>>> Thanks,
>>> -walcir
Re: [ATL] XMI tutorial [message #16639 is a reply to message #16605] Thu, 15 February 2007 10:01 Go to previous message
Originally posted by: freddy.allilaire.univ-nantes.fr
Hi Walcir,
If you are using KM3 to create a metamodel, you need other "tools" to
create an input model that conforms to your metamodel (unless you want
to use KM3 models as input).
Build some UML models will only be useful if the UML metamodel is an
input metamodel of your ATL transformation (i.e. if you want to
transform UML models).
I advise you against writing XMI file by hand. As Ed said, it's complex.
If you want to use visual tools, you can take a look to GMF, Topcased, etc.
Freddy.
Ed Merks a écrit :
> Walcir,
>> Ed,
>> -walcir
>> Ed Merks wrote:
>>> Walcir,
>>>> Hi,
>>>> Thanks,
>>>> -walcir
Previous Topic:[ATL] New ATL use case: Software Build Tools Interoperability (Make, Ant, Maven)
Next Topic:How to create safe "models"
Current Time: Wed Jul 16 05:38:35 EDT 2025
Powered by FUDForum. Page generated in 0.27674 seconds
