Home » Language IDEs » C / C++ IDE (CDT) » default compiler
default compiler [message #174914] Tue, 15 August 2006 17:16 Go to next message
Originally posted by: Thomas.Schmid.Pfaffenberg.de
I use cdt within suse linux 10.1. Creating a new project with managed make
sets the G++ compiler. Is it possible to set the GCC compiler as the default
compiler?
Re: default compiler [message #174921 is a reply to message #174914] Tue, 15 August 2006 18:01 Go to previous messageGo to next message
> compiler?
gcc is for compiling C code only. g++ is the GNU compiler for C++. You
probably set up your project as a Managed make C++ project instead of a
Managed Make C project. Try using a C project instead of C++, then the
default compiler should be gcc.
Re: default compiler [message #175002 is a reply to message #174921] Thu, 17 August 2006 15:08 Go to previous message
Originally posted by: Thomas.Schmid.Pfaffenberg.eu
gcc compiles also C++ altough linking must be done with g++ (see Stallman,
An Introduction to GCC).
Nevertheless, is it possible to configure the default environment?
"Benjamin Cherian" <bjcbell@gmail.com> schrieb im Newsbeitrag
news:pan.2006.08.15.22.01.17.550155@gmail.com...
>> make
>> default
>> compiler?
Previous Topic:UML Class Diagrams
Next Topic:AST - How to get body of IfdefStatement ?
Current Time: Fri Jul 18 01:35:40 EDT 2025
Powered by FUDForum. Page generated in 0.04404 seconds
