Home » Archived » M2M (model-to-model transformation) » How to create safe "models"
How to create safe "models" [message #16525] |
Wed, 14 February 2007 09:06  |
Originally posted by: walcir.fontanini.cenpra.gov.br
I am a newcomer to ATL and I would like to know if there is a safe way
(or preferably a visual tool) to create "models". I have found several
distincts examples of models, like the excerpts below. What about this
tool
http://wiki.eclipse.org/index.php/Modeling_Corner#eUML2_-_UM L_.26_EMF_Designer
[ KM3-KM3.ecore from KM32DOT example ]
<?xml version="1.0" encoding="ISO-8859-1"?>
<Metamodel xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="KM3"
location="1:1-83:2">
<contents location="7:1-83:2" name="KM3">
<contents xsi:type="Class" location="9:9-11:10"
name="LocatedElement" isAbstract="true">
<structuralFeatures xsi:type="Attribute" location="10:17-10:45"
name="location" lower="1" upper="1" isOrdered="false"
type="//@contents.0/@contents.2"/>
</contents>
[ outClassXMI.ecore from Class2Relational example ]
<?xml version="1.0" encoding="ASCII"?>
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns="Class">
<Class name="Family">
<attr name="name" multiValued="false" type="/2"/>
<attr name="members" multiValued="true" type="/1"/>
</Class>
<Class name="Person">
<attr name="firstName" multiValued="false" type="/2"/>
<attr name="closestFriend" multiValued="false" type="/1"/>
<attr name="emailAddresses" multiValued="true" type="/2"/>
</Class>
<DataType name="String"/>
<DataType name="Integer"/>
</xmi:XMI>
-walcir fontanini
CEnPRA
Re: How to create safe "models" [message #16655 is a reply to message #16622] |
Fri, 16 February 2007 05:40   |
Hi Walcir,
Can you please send me your .ecore metamodel for a quick look?
Dimitrios
walcir fontanini wrote:
> Hi Dimitrius,
> I have downloaded Exeed from
> http://www-users.cs.york.ac.uk/~dkolovos/epsilon/bundles/bun dle-win.php
> and unzip the file to d:\ directory. After executing eclipse.exe
> But it did NOT worked. It does not produced any extra icons typical from
> Exeed ! Any hint for me ?
> -walcir
> Dimitrios Kolovos wrote:
>> Hi Walcir,
>> You may want to take a look at
>> http://wiki.eclipse.org/index.php/ATL_FAQ#I_can_use_KM3_to_c reate_metamodels.2C_but_what_about_models.3F
>> and http://wiki.eclipse.org/index.php/Modeling_Corner#Exeed
>> Cheers,
>> Dimitrios
>>> Hi,
>>> way (or preferably a visual tool) to create "models". I have found
>>> several distincts examples of models, like the excerpts below. What
>>> about this tool
>>> </contents>
>>> xmlns="Class">
>>> </Class>
>>> </Class>
>>> </xmi:XMI>
>>> Thanks,
>>> -walcir fontanini
>>> CEnPRA
Re: How to create safe "models" [message #16672 is a reply to message #16655] |
Fri, 16 February 2007 11:23   |
Dimitrius,
It was not my own ecore model, but the problem occurred with
OOinstance.ecore (even after "Register ecore Metamodel" on OO.ecore).
The same problem happens to DBInstance.ecore/DB.ecore pair.
-walcir
> Hi Walcir,
> Cheers,
> Dimitrios
>> Hi Dimitrius,
>> from Exeed ! Any hint for me ?
>> Thanks,
>> -walcir
>>> Hi Walcir,
>>> Cheers,
>>> Dimitrios
>>>> Hi,
>>>> about this tool
>>>> location="10:17-10:45" name="location" lower="1" upper="1"
>>>> isOrdered="false" type="//@contents.0/@contents.2"/>
>>>> </contents>
>>>> xmlns="Class">
>>>> </Class>
>>>> </Class>
>>>> </xmi:XMI>
>>>> Thanks,
>>>> -walcir fontanini
>>>> CEnPRA
Re: How to create safe "models" [message #16689 is a reply to message #16672] |
Fri, 16 February 2007 11:08   |
Hi Walcir,
I see. The OO.ecore that comes with the Epsilon bundle that you have
downloaded is not annotated for Exeed. You can find an annotated version
in the example provided at
http://dev.eclipse.org/viewcvs/indextech.cgi/org.eclipse.gmt /epsilon/examples/ExeedOO/ExeedOO.zip
(as discussed in the Exeed manual).
Dimitrios
> Dimitrius,
> -walcir
>> Hi Walcir,
>> Cheers,
>> Dimitrios
>>> Hi Dimitrius,
>>> Thanks,
>>> -walcir
>>>> Hi Walcir,
>>>> Cheers,
>>>> Dimitrios
>>>>> Hi,
>>>>> about this tool
>>>>> </contents>
>>>>> xmlns="Class">
>>>>> </Class>
>>>>> </Class>
>>>>> </xmi:XMI>
>>>>> Thanks,
>>>>> -walcir fontanini
>>>>> CEnPRA
Current Time: Mon Sep 01 01:15:31 EDT 2025
Powered by FUDForum. Page generated in 0.09610 seconds
