Unable to start eclipse 3.2 on linux [message #174847] |
Sun, 15 October 2006 18:52 |
Originally posted by: Sofija.xtra.co.nz
When trying to launch eclipse (by typing the command on the command line),
after an apparent attempt to do so, eclipse crashes and advises me about
the error and the log file in configuration directory.
Here is example of a log file's content:
!SESSION 2006-10-01 18:38:06.571
eclipse.buildId=M20060629-1905
java.version=1.4.2
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.update.configurator 4 0 2006-10-01 18:38:07.644
!MESSAGE FrameworkEvent.ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.update.internal.configurator.ConfigurationActiva tor.start() of
bundle org.eclipse.update.configurator.
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1014)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:317)
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:329)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1037)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:573)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:495)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:275)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:455)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:189)
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:291)
Caused by: org.eclipse.core.runtime.CoreException: Cannot create
configuration in file:/opt/user/eclipse/configuration/
org.eclipse.update.internal.configurator.Utils.newCoreExcept ion(Utils.java:85)
org.eclipse.update.internal.configurator.ConfigurationActiva tor.initialize(ConfigurationActivator.java:113)
org.eclipse.update.internal.configurator.ConfigurationActiva tor.start(ConfigurationActivator.java:71)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:995)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:989)
... 10 more
Root exception:
org.eclipse.core.runtime.CoreException: Cannot create configuration in
!ENTRY org.eclipse.core.runtime 4 0 2006-10-01 18:38:07.648
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved.
Reason: Missing Constraint: Require-Bundle: org.eclipse.core.jobs;
bundle-version="[3.2.0,4.0.0)"
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:294)
!ENTRY org.eclipse.osgi 4 0 2006-10-01 18:38:07.653
!MESSAGE Bundle
initial@reference :file:plugins/org.eclipse.update.configurator_3.2.0.v2006060 5.jar/
[2] is not active.
!ENTRY org.eclipse.osgi 4 0 2006-10-01 18:38:07.654
!MESSAGE Bundle
initial@reference:file:plugins/org.eclipse.core.runtime_3.2.0.v20060603.jar/
was not resolved.
!ENTRY org.eclipse.osgi 4 0 2006-10-01 18:38:07.658
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service.
Ensure that the org.eclipse.core.runtime bundle is resolved and started
(see config.ini).
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:65)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!ENTRY org.eclipse.osgi 2 0 2006-10-01 18:38:07.667
!MESSAGE One or more bundles are not resolved because the following root
constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2006-10-01 18:38:07.667
!MESSAGE Bundle
was not resolved.
!SUBENTRY 2 org.eclipse.core.runtime 2 0 2006-10-01 18:38:07.667
!MESSAGE Missing required bundle
org.eclipse.core.contenttype_[3.2.0,4.0.0).
org.eclipse.equinox.registry_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.core.jobs_[3.2.0,4.0.0).
!SUBENTRY 2 org.eclipse.core.runtime 2 0 2006-10-01 18:38:07.668
org.eclipse.equinox.preferences_[3.2.0,4.0.0).
Re: Unable to start eclipse 3.2 on linux [message #177921 is a reply to message #174847] |
Wed, 01 November 2006 18:29 |
Originally posted by: intrader.aol.com
> line), after an apparent attempt to do so, eclipse crashes and advises
> me about the error and the log file in configuration directory.
> java.version=1.4.2
> !STACK 0
> of bundle org.eclipse.update.configurator.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> ... 10 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !MESSAGE Bundle
> [2] is not active.
> !MESSAGE Bundle
> was not resolved.
> !STACK 1
> (see config.ini).
> at
> at
> at
> at
> at
> !MESSAGE Bundle
> was not resolved.
I had this problem when I did not have permissions. What I did to solve
this might no be kosher, but I set the owner of/opt/user to myself.
I hope this helps
FUDForum. Page generated in 8.91255 seconds
