Home » Eclipse Projects » Eclipse Platform » plugins in directory other than $ECLIPSE_HOME/plugins
plugins in directory other than $ECLIPSE_HOME/plugins [message #16494] Fri, 25 April 2003 15:56 Go to next message
I was wondering if it is possible to tell Eclipse on startup where to find
a plugin that is not in the /plugins directory. I understand that there is
a -configuration option that takes a configurationFileURL as a parameter,
but I am uncertain about how to go about creating this file.
Jennifer
Re: plugins in directory other than $ECLIPSE_HOME/plugins [message #16512 is a reply to message #16494] Fri, 25 April 2003 16:44 Go to previous messageGo to next message
you can do that by creating a links subdir next to plugins and
putting a xyz.links file in there with the content of
|path=/usr/local/lib
(example used by debian packages, needs to be a absolute pathname)
It would be nice if eclipse could also take this as a commandline
parameter:
http://bugs.eclipse.org/bugs/show_bug.cgi?id=36101
Jan
Re: plugins in directory other than $ECLIPSE_HOME/plugins [message #17527 is a reply to message #16494] Sat, 26 April 2003 16:18 Go to previous message
Jennifer,
Use
Run -> Run -> Plug-ins and Fragements -> Choose plug-ins and fragments to
lauch from the list
to tell Eclipse to pick up plugins from your workspace. This creates a
configurationFileURL something like
file:/home/dgeg/eclipseWorkspace/.metadata/.plugins/org.ecli pse.pde.core/_home_dgeg_.dpkgue/platform.cfg
In a couple days I'll post an example where I use a platform.cfg to pick
up plugins from a 2nd site.
Don
Jennifer Lhotak wrote:
> Thanks
> Jennifer
Previous Topic:Outline View of a View
Next Topic:New to Eclipse
Current Time: Mon Jul 14 02:22:20 EDT 2025
Powered by FUDForum. Page generated in 0.05915 seconds
