Home » Eclipse Projects » SWTBot » can't find button
can't find button [message #16476] Wed, 21 January 2009 11:52 Go to next message
This in fact is not a question. I had problem to find a button widget.
I found the solution and want to share it.
Maybe one day it will be usefull for someone.
Problem:
bot.button("xyz") was throwing NotFound exception
... but my "xyz" button was really in the app ...
I noticed that the button in my app was TOGGLE style.
I noticed that the button(string) function was looking only for PUSH style
button.
Therefore it would never find my button.
The solution is to make a matcher with just the string and class
constraints.
Marc
Re: can't find button [message #16631 is a reply to message #16476] Thu, 22 January 2009 06:19 Go to previous messageGo to next message
Thanks Marc,
Can you send a piece of your code?
Re: can't find button [message #17497 is a reply to message #16631] Thu, 22 January 2009 09:07 Go to previous message
Here is my code,
it clicks on the 0th button whatever its style.
Matcher matcher = WidgetMatcherFactory.widgetOfType(Button.class);
(new SWTBotButton((Button) bot.widget(matcher, 0))).click();
Here is swtbot.class code that shows the button-style constraint:
public SWTBotButton button(int index) {
Matcher matcher = allOf(widgetOfType(Button.class), withStyle(SWT.PUSH,
"SWT.PUSH"));
return new SWTBotButton((Button) widget(matcher, index));
Perhaps the javadoc could mention the SWT.PUSH constraint.
Bye
Marc
Previous Topic:Eclipse doesn't show launcher configuration "SWTBot Test"
Next Topic:press enter in a table
Current Time: Tue Jun 24 21:05:55 EDT 2025
Powered by FUDForum. Page generated in 0.03834 seconds
