Problem with new org.apache.axis bundle [message #16469] |
Sun, 29 March 2009 09:40  |
I tried to use the new org.apache.axis bundle from the orbit build
I20090320075422. The bundle is not usable in PDE. I can add the bundle
to the target and PDE shows the bundle with its manifest but the
exported classes are not visible in eclipse. For a bundle using axis
code, the compiler complains "The import org.apache connot be resolved".
The bundle from S20090307012903 works as expected. Also, the newer
I20090320075422 bundle works if I unzip it. Apparently, the problem
comes from the fact that the newer bundle is jarred and the older one
was not. But I think, it should also work in the jarred form.
Best regards
Peter
Re: Problem with new org.apache.axis bundle [message #16487 is a reply to message #16469] |
Tue, 31 March 2009 16:49  |
I'm opened bug 270669 for this.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=270669
Re: Problem with new org.apache.axis bundle [message #565273 is a reply to message #16469] |
FUDForum. Page generated in 0.12830 seconds
