Home » Language IDEs » PHP Development Tools (PDT) » Debugging files NOT under the document root
Debugging files NOT under the document root [message #16457] Fri, 20 April 2007 06:49 Go to next message
For improved security it's a good practice to put back-end source files
NOT under the document root, but somewhere else.
I want to know is it possible to debug those files with PDT/XDebug and
the new path mapper and how should it be configured.
Emil Ivanov
Re: Debugging files NOT under the document root [message #16475 is a reply to message #16457] Fri, 20 April 2007 09:24 Go to previous messageGo to next message
It should be possible and depending on how you create your setup, you may or may not
need to use a path mapper.
Whenever a script is executing within PHP, XDebug will know its complete path.
In order for PDT to be able to
a) show the correct script when editing
b) send breakpoints to PHP/XDebug
either
1) the script being executed by PHP is the same physical file contained within your workspace
2) we need some way to map a relationship between the physical file PHP is executing and the
physical copy of the file that exists in the PDT workspace
If you have a setup that reflects 1), then you don't need a path mapper
If you have a setup that reflects 2), then you need a path mapper.
The sample path mapper I provided will map a single directory path for the web server scripts
(it doesn't have to be your htdocs location, even though it is labeled like that) to a single path within your workspace.
So you need to work out how you directory of scripts (not in htdocs) will map
to the copies contained in your workspace based on the above.
If you have scripts in htdocs and outside of htdocs, it may still be possible to
to use my sample mapper to debug scripts in both places if you require.
Dave Kelsey
> Emil Ivanov
Re: Debugging files NOT under the document root [message #16510 is a reply to message #16475] Fri, 20 April 2007 12:18 Go to previous message
Thanks for the quick response. I got it running - and...
Ima tell ya, that thing rocks. Thanks again and keep up the good work.
> may or may not
> path.
> either
> will map
> possible to
> Dave Kelsey
Previous Topic:Please help vote for the Mylar/PDT bridge.
Next Topic:[Semi-OT] Is it possible to select all text between braces?
Current Time: Sun Aug 31 21:05:20 EDT 2025
Powered by FUDForum. Page generated in 0.10034 seconds
