Home » Modeling » TMF (Xtext) » SPL sample context for LocalFunctionDeclarations
SPL sample context for LocalFunctionDeclarations [message #16444] |
Tue, 01 July 2008 10:20  |
I am looking at the SPL sample from the TCS Zoo, and am a bit puzzled
about a detail concerning the contexts.
I was curious about SPL, so I tried a different sample than the one in
CVS. I got a reference setting error, so I looked at the example in more
detail.
Particularly, you'll notice that the root element is a Service, which may
contain Declarations, which may be LocalFunctionDeclarations.
None of the supertypes of LocalFunctionDeclaration is declared as context
element in the syntax:
template Declaration abstract;
template FunctionDeclaration abstract;
template LocalFunctionDeclaration addToContext : ...
Now in the example from the SPL website, there is this snippet:
service queue {
processing {
FIFO string<4> remove_element ( string call_id, FIFO string<4> list )
void play(string call_id, int index) {
select(index) {
case 0: rtp_play(call_id, "attendee.wav"); return;
please pay attention to the argument "call_id". In the select statement,
to resolve the call_id declaration, a lookup is done in the context. Since
the context here is the service, the lookup finds 2 arguments (Argument
being a subtype of Declaration) with the name "call_id", on in each of the
2 methods "remove_element" and "play".
Am I just missing something or is the SPL syntax missing the context
keyword somewhere to make the sample work?
I could not get Injection run because my environment is broken at this
time, so I don't know if injection right now would run or not. The example
I used is from the site:
http://phoenix.labri.fr/software/spl/
Re: [] SPL sample context for LocalFunctionDeclarations [message #16566 is a reply to message #16444] |
Wed, 09 July 2008 11:04   |
Please, remember to prefix the subject of your TCS-related posts with
[TCS] as I did in this message.
Thanks.
It seems that there is indeed a missing "context".
Frédéric Jouault
Thibault a écrit :
> detail.
> may contain Declarations, which may be LocalFunctionDeclarations.
> context element in the syntax:
> service queue {
> processing {
> select(index) {
> Since the context here is the service, the lookup finds 2 arguments
> (Argument being a subtype of Declaration) with the name "call_id", on in
> each of the 2 methods "remove_element" and "play".
> keyword somewhere to make the sample work? I could not get Injection run
> because my environment is broken at this time, so I don't know if
> injection right now would run or not. The example I used is from the site:
Re: [TCS] SPL sample context for LocalFunctionDeclarations [message #16582 is a reply to message #16566] |
Wed, 09 July 2008 11:05  |
It seems that I have some difficulty with the prefix today :-/.
Frédéric Jouault
Frédéric Jouault a écrit :
> Thanks.
> Frédéric Jouault
> Thibault a écrit :
>> more detail.
>> service queue {
>> processing {
>> select(index) {
>> statement, to resolve the call_id declaration, a lookup is done in the
>> context. Since the context here is the service, the lookup finds 2
>> arguments (Argument being a subtype of Declaration) with the name
>> "call_id", on in each of the 2 methods "remove_element" and "play".
>> run because my environment is broken at this time, so I don't know if
>> site:
Current Time: Sun Aug 31 21:04:55 EDT 2025
Powered by FUDForum. Page generated in 0.03445 seconds
