Home » Eclipse Projects » DSDP - Target Management » TM 2.0.2 and 3.0M3 are released
TM 2.0.2 and 3.0M3 are released [message #16428] Wed, 14 November 2007 16:20 Go to next message
We are pleased to announce that Target Management 2.0.2
and 3.0M3 are now available for download.
TM 2.0.2 contains 24 bug fixes, mostly fixing the critical regressions
that were found in the new Terminal shortly after TM 2.0.1. It also
contains two fixes regarding file upload.
TM 3.0M3 includes a Terminal Fix specific for Eclipse 3.4M3, API changes
improving the remote file services (performance, events), and more than
40 additional bug fixes.
For more details, and download links, see
http://www.eclipse.org/dsdp/tm/
If you have TM 2.0.x installed, you can also upgrade to 2.0.2 using
update manager - it's 100% upward and backward compatible. Also, TM
2.0.2 has been published on the Europa Discovery Site as part of the
Europa Fall maintenance release respin related to Eclipse 3.3.1.1.
Enjoy!
Martin Oberhuber
Target Management Project Lead, DSDP PMC Member
TM 3.0M5 is released [message #18501 is a reply to message #16428] Mon, 18 February 2008 19:50 Go to previous message
We are pleased to announce that Target Management 3.0M5 is available for
download.
News for Users include
* UI for viewing and changing file permissions and owner on UNIX
* SSH Keepalive mechanism
* Link with Editor action fixed
* Ctrl+Space Field Assist for history in the Terminal input field
On the internals, TM 3.0M5 provides faster startup and reduced footprint
thanks to improved lazy loading of filter pools; and the SystemRegistry
implementation has moved to non-UI plugins for improved UI/Non-UI
Separation.
See the build notes for more information:
http://download.eclipse.org/dsdp/tm/downloads/drops/S-3.0M5- 200802181400/
As always, the build is available for download and on the TM milestone
update site, and will be on the Ganymede Update Site soon.
Enjoy!
Martin Oberhuber
Wind River Systems, Inc.
TM 3.0M5 is released [message #572296 is a reply to message #16428] Mon, 18 February 2008 19:50 Go to previous message
download.
Separation.
Enjoy!
Martin Oberhuber
Previous Topic:RSE hangs on FTP import
Next Topic:TM 3.0M5 is released
Current Time: Fri Jul 18 00:43:17 EDT 2025
Powered by FUDForum. Page generated in 0.03561 seconds
