Re: [Sample Ecore Editor] Edit operation parameters [message #173735 is a reply to message #173715] |
Fri, 22 February 2008 09:31   |
--------------060302060409070109050403
Stefan,
Have you tried the graphical editor provided by the Ecore Tools
component of EMFT?
http://www.eclipse.org/modeling/emft/?project=ecoretools
It's being developed by the same folks who did the Topcased one. I think
there might be problems if you install the GMF one and the Ecore Tools
one together, so best to delete/disable the GMF one...
Stefan Bley wrote:
> some months ago I already pointed out that it is not possible to set
> the parameters of EOperation in the GMF Sample Ecore Editor.
> Since I hope this will get fixed sooner or later, I would like to
> reference to Topcased's Ecore Editor that provides this feature. Maybe
> there could be some kind of knowledge transfer.
> http://topcased-mm.gforge.enseeiht.fr/website/modeling/ecore /
> Regards, Stevy
<html>
<head>
http-equiv="Content-Type">
</head>
Stefan,<br>
<br>
component of EMFT?<br>
<blockquote><a
href="http://www.eclipse.org/modeling/emft/?project=ecoretools">http://www.eclipse.org/modeling/emft/?project=ecoretools</a><br>
</blockquote>
think there might be problems if you install the GMF one and the Ecore
Tools one together, so best to delete/disable the GMF one...<br>
<br>
Stefan Bley wrote:
<blockquote cite="mid:fpmlul$1v6$1@build.eclipse.org" type="cite">Hi,
<br>
<br>
<br>
<br>
<br>
<a class="moz-txt-link-freetext" href=" http://topcased-mm.gforge.enseeiht.fr/website/modeling/ecore /"> http://topcased-mm.gforge.enseeiht.fr/website/modeling/ecore /</a>
<br>
<br>
Regards, Stevy
<br>
</blockquote>
<br>
</body>
</html>
--------------060302060409070109050403--
Re: [Sample Ecore Editor] Edit operation parameters [message #173803 is a reply to message #173779] |
Fri, 22 February 2008 11:48  |
Yes, Ecore Tools is not compliant with Eclipse Europa version. As we
started a few months ago, and that we highly depends on the new features
developed as part of GMF, we are targeting the Ganymede release only for
the moment, so you need to install the corresponding 3.4 milestone version.
>> component of EMFT?
> Unlike Topcased's version, the Ecore editor from EMFT makes my Eclipse
> instance hang up. Is it compatible to Europa compliant plugins or do I
> need newer ones (e.g. EMF)?
> What I would like to do is to re-use the editor/edit parts of Ecore in
> my own editor. E.g. I want to provide a meta element "Operation" and
> re-use the edit/editor parts of EOperation. Especially the new
> "Parameters" tab in EOperation's properties view.
> Stefan
FUDForum. Page generated in 0.04429 seconds
