Home » Modeling » GMF (Graphical Modeling Framework) » creating file
creating file [message #173646] |
Fri, 22 February 2008 06:48  |
Originally posted by: aritz.galdos.iese.fraunhofer.de
Good afternoon!!!
I have created my own diagram editor by GMF. And now, when the users makes
an action, I have to create a diagram-file. When wou create a diagram, two
files are created: test.xxx and test.xxx_diagram. (xxx is the name that I
have given to my model).
So, is any method, or class that creates both files together? or, have I got
to create both files manually, I mean:
IFile myFile1 = myProject.getFile(test.xxx );
IFile myFile1 = myProject.getFile(test.xxx?diagram );
Because I know, that some info is stored from the beginning in one of the
files.
Thank you in advance
Aritz
Re: creating file [message #174732 is a reply to message #173662] |
Thu, 28 February 2008 03:44   |
Hello!
Thank you for your answer, but now I have another problem. I can't acces to
domainModel... variables. I have imported their packages, but it doesn't
recognize it. My code is the next.
//supposedly, to create the file
Resource r =
RuntimeViewmodelDiagramEditorUtil.createDiagram(domainModelF ilePage.getURI(),
domainModelFilePage.getURI(), progressMonitor);
//getting the editor
IWorkbenchPage page =
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage();
IEditorInput myEditorInput = new FileEditorInput(myDiagramFile);
IEditorDescriptor desc =
PlatformUI.getWorkbench().getEditorRegistry().getDefaultEdit or();
String myDescId = desc.getId();
try {
EditorPart myEditor = (EditorPart) page.openEditor(myEditorInput, myDescId);
DiagramDocumentEditor myDiagramDocumentEditor = (DiagramDocumentEditor)
myEditor;
Diagram myDiagram = myDiagramDocumentEditor.getDiagram();
I know that the domainModel... is defined in RuntimeViewmodelCreationWizard,
but it doesn't recognize the variable. So, what can I do to solve my
problem? I don't know if I need the other code that I have writen above, I
did it just in case.
Thank in advance, and I am sorry because of my poor English.
Aritz
"Alex Shatalin" <vano@borland.com> wrote in message
news:3c3172e61e6168ca436abc20c99d@news.eclipse.org...
> Hello Aritz,
> See generated
> xxxDiagramEditorUtil.createDiagram(diagramModelFilePage.getU RI(),
> domainModelFilePage.getURI(), monitor)
> Alex Shatalin
Re: creating file [message #174750 is a reply to message #174732] |
Thu, 28 February 2008 04:04   |
Hello again!!!
I have my URI of the diagram that I want to create, but it seems that
"xxxDiagramEditorUtil.createDiagram" method suposses that I have created a
model. So, is there any posibility to create the two files (the model and
the diagram?), instead of creating apartly? Unless, how can I create the
model, to get its URI, the second parameter of
xxxDiagramEditorUtil.createDiagram method?
Thank you in advance!!
Don't pay attention to the other question, thak you, and sorry because of my
poor English!!
Aritz
"Aritz" <aritz.galdos@iese.fraunhofer.de> wrote in message
news:fq5sa2$sh6$1@build.eclipse.org...
> Hello!
> to domainModel... variables. I have imported their packages, but it
> doesn't recognize it. My code is the next.
> Resource r =
> try {
> myDescId);
> myEditor;
> RuntimeViewmodelCreationWizard, but it doesn't recognize the variable. So,
> what can I do to solve my problem? I don't know if I need the other code
> that I have writen above, I did it just in case.
> Aritz
>> Hello Aritz,
>> See generated
>> Alex Shatalin
Re: creating file [message #174854 is a reply to message #174750] |
Thu, 28 February 2008 11:17  |
Hello again!!
I am getting my staff step by step, but now I have another problem I want to
create the diagram file and the "supporting" file. My code is the nest one:
//getting the workspace
IWorkspace myWorkspace =
org.eclipse.core.resources.ResourcesPlugin.getWorkspace();
//getting the root of the workspace
IWorkspaceRoot myWorkspaceRoot = myWorkspace.getRoot();
//getting the project
String projectName = uri.segment(1); //to get the name of the project
IProject myProject = myWorkspaceRoot.getProject(projectName);
//getting the files: diagram and xml
String diagramName = traceName + "." + extensionDiagram;
IFile myDiagramFile = myProject.getFile(diagramName);
String fileName = traceName + "." + extension;
IFile myFile = myProject.getFile (fileName);
//getting and creating the path to store the diagram
URI uriDiagram = URI.createPlatformResourceURI(projectName, false);
URI uriFile = URI.createPlatformResourceURI(projectName, false);
uriDiagram =
uriDiagram.appendSegment(traceName).appendFileExtension(exte nsionDiagram);
uriFile = uriFile.appendSegment(traceName).appendFileExtension(extensi on);
//creating the files
TransactionalEditingDomain editingDomain =
GMFEditingDomainFactory.INSTANCE.createEditingDomain();
Resource diagramResource =
editingDomain.getResourceSet().createResource(uriDiagram);
Resource fileResource =
editingDomain.getResourceSet().createResource(uriFile);
Resource rD = RuntimeViewmodelDiagramEditorUtil.createDiagram(uriDiagram,
diagramResource.getURI(), new NullProgressMonitor());
Resource rF = RuntimeViewmodelDiagramEditorUtil.createDiagram(uriFile,
fileResource.getURI(), new NullProgressMonitor());
try {
if (!RuntimeViewmodelDiagramEditorUtil.openDiagram(rD))
MessageDialog.openInformation(shell, "Error", "It is not possible to open
the diagram");
} catch (PartInitException e) {
the diagram");}
PlatformUI.getWorkbench().getEditorRegistry().getDefaultEdit or(diagramName);
try {
myEditor;
//processing domain-specific information: the referenced business model
element
EObject myUnderlyingDomainElement = myDiagram.getElement();
//implementing the listener, for the changed made in the runtime view
myUnderlyingDomainElement.eAdapters().add(new RTViewmodelListener(trace));
catch (Exception e) {
System.out.println("PartInitException: " + e);}
So, my problem is: when I create a diagram manually (file --> new -->
runtimeviewmodel diagram...) I can open it, modify... thee by the editor, I
mean, I can add objects to my diagram. The problem is that if I create the
diagram by the code above, I can't do anything by the editor, only open it.
Can anybody help me? Thank you very much!!! (Sorry because of my poor
English!!)
Aritz
news:fq5tf6$1lj$1@build.eclipse.org...
> Hello again!!!
> my poor English!!
> Aritz
>> Hello!
>> Resource r =
>> try {
>> myDescId);
>> myEditor;
>> So, what can I do to solve my problem? I don't know if I need the other
>> code that I have writen above, I did it just in case.
>> Aritz
>>> Hello Aritz,
>>> See generated
>>> Alex Shatalin
Current Time: Thu Jul 10 01:49:45 EDT 2025
Powered by FUDForum. Page generated in 0.07045 seconds
