Re: BIRT 2.1.0 distribution missing some plugin metadata? [message #16895 is a reply to message #16869] |
Tue, 13 June 2006 05:32   |
Linda,
Thanks for the clarification. If the DTP modelbase is not being used
then I'll assume the platform failures to initialize the bundles can be
ignored.
BTW, the versions I am using are all from Callisto RC4. Well nearly -
the TPTP page links to a slightly earlier release of BIRT (N20060530
instead of M-R1-2.1RC4 but both are missing manifests). I can wait
until the next Callisto release to pick up a cleaner build. I presume
the BIRT reporting framework distribution will no longer internally
contain any DTP plugins?
John.
Linda Chan wrote:
> The DTP modelbase plugins, as included in the BIRT N20060530 build, are
> indeed incomplete. The BIRT build should not have included these DTP
> modelbase plugins in the first place.
> They are no longer included since the BIRT 20060602 build.
> A work-around is to manually remove all the DTP modelbase plugins from
> your installation, since they are not used by BIRT.
> Or, if you want to get the complete DTP plugins, download the version
> distributed by DTP download page or the Callisto update site.
> Linda
> John O'Shea wrote:
>> I've installed the BIRT 2.1.0 zip (1) for TPTP 4.2.0 (as
>> recommended at bottom of (2)) to enable reporting from the
>> <tptp:publication> ant task and I noticed that on startup the Error
>> Log is reporting a number of errors installing BIRT bundles. For
>> example:
>> Error
>> Mon Jun 12 12:09:49 BST 2006
>> Plugin does not have a valid version:
>> plugins/org.eclipse.datatools.modelbase.sql_0.9.0.200605101/
>> Error
>> plugins/org.eclipse.datatools.modelbase.sql.xml.query_0.9.0. 200605101/
>> Presumably these plugins are coming from DTP, and looking at the
>> offending plugin folders, they do seem to be missing Manifest files.
>> Has anyone else noticed this? Should TPTP be using a revised BIRT/DTP
>> distribution?
>> (1)
> http://www.eclipse.org/downloads/download.php?file=/birt/dow nloads/drops/N-R1-N20060530-200605300632/birt-report-framewo rk-N20060530.zip
>> (2)
> http://www.eclipse.org/tptp/home/downloads/drops/TPTP-4.2.0- 200605251528B.html
Re: BIRT 2.1.0 distribution missing some plugin metadata? [message #17100 is a reply to message #17043] |
Fri, 16 June 2006 05:29  |
Linda Chan wrote:
> Yes, I do see the issue you'd described.
> Please submit a Bugzilla entry for the BIRT Build component on this, and
> specify which BIRT download package(s) that you use.
Done - https://bugs.eclipse.org/bugs/show_bug.cgi?id=147419
It's not quite as big a problem - at least at the moment BIRT is
redistributing the 'correct' version of DTP but it would be good to make
the BIRT distro leaner. (There is also the danger that in the future we
may need to combine a patched version of DTP with BIRT)
> It should be ok, though, for the BIRT "all-in-one" package to continue
> include its dependent DTP plugins, right?
Yes, I don't see why not!
Re: BIRT 2.1.0 distribution missing some plugin metadata? [message #579498 is a reply to message #16390] |
Mon, 12 June 2006 15:05  |
Linda
John O'Shea wrote:
> I've installed the BIRT 2.1.0 zip (1) for TPTP 4.2.0 (as recommended
> at bottom of (2)) to enable reporting from the <tptp:publication> ant
> task and I noticed that on startup the Error Log is reporting a number
> of errors installing BIRT bundles. For example:
> Error
> Error
> distribution?
> (1)
> (2)
Re: BIRT 2.1.0 distribution missing some plugin metadata? [message #579512 is a reply to message #16869] |
Linda,
ignored.
John.
> Linda
> John O'Shea wrote:
>> example:
>> Error
>> Error
>> distribution?
>> (1)
>> (2)
Re: BIRT 2.1.0 distribution missing some plugin metadata? [message #579534 is a reply to message #16924] |
Wed, 14 June 2006 03:24  |
The reason I asked is that we typically combine BIRT distributions with
tothers from Callisto - WTP (and it's dependents), DTP etc. Having a
second (different) DTP distribution inside the BIRT reporting framework
causes two sets of DTP plugins to get dropped into our Eclipse installation.
It's not a big problem, we can manually remove the DTP plugins from the
BIRT zip and re-distribute it, I was just hoping the distro coming from
you guys would be trimmed down (and the download page would have a link
to the compatable DTP runtime...
John.
Linda Chan wrote:
> John,
>>> I presume the BIRT reporting framework distribution will no longer internally
> It does contain those DTP plugins that are needed by BIRT. That includes the DTP ODA plugins and a couple other DTP connectivity plugins.
> Linda
Re: BIRT 2.1.0 distribution missing some plugin metadata? [message #579668 is a reply to message #17043] |
FUDForum. Page generated in 0.06411 seconds
