Home » Eclipse Projects » Plugin Development Environment (PDE) » How to enable or disable an action based on the kind of selection?
How to enable or disable an action based on the kind of selection? [message #16387] Sun, 17 August 2008 16:28 Go to next message
Originally posted by: nick.allen.onlinehome.de
I am new to Eclipse plugin development and am having a problem that I
thought would be easy but doesn't seem to be.
Basically, I have some actions in my plugin that appear in Eclipse's
menu bar and I want to change their enabled state based on the current
selection.
What I assumed I would have to do is override the selectionChanged
method from the IWorkbenchWindowActionDelegate interface and use the
selection passed in to decide and update the action's enabled state.
Unfortunately, this does not work because the delegate is only created
after it has been invoked at least once. This means it starts off
enabled and after I select it I get an error from Eclipse "Operation not
available" and then the correct enabled state is set on it based on the
selection.
Of course, I don't want the user to have to invoke my action at least
once in order to get the correct enabled state shown. Basically, I need
to know when selection is changed before my action delegate has been
invoked. How do I do this?
Any help greatly appreciated.
Many thanks in advance,
Nicholas Allen
Re: How to enable or disable an action based on the kind of selection? [message #16964 is a reply to message #16387] Mon, 18 August 2008 04:43 Go to previous messageGo to next message
Could it be I need to use the handlers and menu extension instead of the
action sets extension?
Nick
Nicholas Allen wrote:
> selection.
> selection.
> Nicholas Allen
Re: How to enable or disable an action based on the kind of selection? [message #17020 is a reply to message #16387] Mon, 18 August 2008 13:53 Go to previous messageGo to next message
I have tried everything I can think of and being new to Eclipse I would
really appreciate if someone more experienced could at least point me in
the right direction. It is such a simple requirement but I cannot find
any way to do it.
Nick
Re: How to enable or disable an action based on the kind of selection? [message #17049 is a reply to message #16387] Mon, 18 August 2008 15:08 Go to previous messageGo to next message
I found this after 2 days of searching. Am I on the right track? Is this
what I need to do? If so, how do I get the IHandlerService in order to
register my expression that decides when my handler is enabled?
The Eclipse documentation is extremely poor with regard to this.
Possible solution I found:
if you only want your handler to be active when you conditions are met,
you can use handlerService.activateHandler("command.id", myHandler,
myExpression) to provide a programmatic core expression. It is just a
subclass of Expression.
Expression expression = new Expression() {
public void collectExpressionInfo(ExpressionInfo info) {
info.addVariableNameAccess(ISources.ACTIVE_CURRENT_SELECTION _NAME);
public EvaluationResult evaluate(IEvaluationContext context)
throws CoreException {
Object o = context
.getVariable(ISources.ACTIVE_CURRENT_SELECTION_NAME);
if (o instanceof IStructuredSelection) {
// work with your selection and return TRUE
return EvaluationResult.FALSE;
Re: How to enable or disable an action based on the kind of selection? [message #17133 is a reply to message #17049] Tue, 19 August 2008 12:01 Go to previous messageGo to next message
Originally posted by: annamalai.ancitconsulting.com
Dear Nicholas
I think if the action is created using ActionSet then it can be achieved
using Selection or Enablement available on the Action ... U can right click
on an action and then you will get these Choices where u can Disable or
enable based on Condition ...
Not really sure if you have been using Menu, Command etc .. then i think
your suggested way looks ok ...
Hope that helps.
Malai
"Nicholas Allen" <nick.allen@onlinehome.de> wrote in message
news:g8chah$82b$1@build.eclipse.org...
> Object o = context
Re: How to enable or disable an action based on the kind of selection? [message #17190 is a reply to message #17133] Tue, 19 August 2008 06:37 Go to previous messageGo to next message
My condition is not something that can be expressed in the XML file for
an action. Basically, I'm writing a plug-in that integrates with the
Bazaar version control system. I need to enable a command based on
whether there is a file selected and it is inside a Bazaar branch (i.e
there is a ".bzr" directory it it or one of its parent directories).
I read the Eclipse documentation and noticed that Action sets are
deprecated in favour of commands and the menu extension. I am now using
this but I still have not found a way to enable or disable my command
handler.
Any help greatly appreciated!
Nick
Malai wrote:
> Dear Nicholas
> Hope that helps.
> Regards
> Malai
>> Object o = context
Re: How to enable or disable an action based on the kind of selection? [message #19806 is a reply to message #17190] Sat, 06 September 2008 11:50 Go to previous message
> handler.
> Nick
See my reply to "Need help with 'menus' extension" posted a few minutes
ago for some ideas about using your own property tester to achieve what
you want.
Mark
Re: How to enable or disable an action based on the kind of selection? [message #576692 is a reply to message #16387] Mon, 18 August 2008 04:43 Go to previous message
Nick
> selection.
> selection.
> Nicholas Allen
Re: How to enable or disable an action based on the kind of selection? [message #576772 is a reply to message #16387] Mon, 18 August 2008 13:53 Go to previous message
any way to do it.
Nick
Re: How to enable or disable an action based on the kind of selection? [message #576793 is a reply to message #16387] Mon, 18 August 2008 15:08 Go to previous message
Object o = context
Re: How to enable or disable an action based on the kind of selection? [message #576926 is a reply to message #17049] Tue, 19 August 2008 12:01 Go to previous message
Dear Nicholas
Hope that helps.
Malai
> Object o = context
Re: How to enable or disable an action based on the kind of selection? [message #576985 is a reply to message #17133] Tue, 19 August 2008 06:37 Go to previous message
handler.
Nick
Malai wrote:
> Dear Nicholas
> Hope that helps.
> Regards
> Malai
>> Object o = context
Re: How to enable or disable an action based on the kind of selection? [message #578870 is a reply to message #17190] Sat, 06 September 2008 11:50 Go to previous message
> handler.
> Nick
you want.
Mark
Previous Topic:Need help with 'menus' extension
Next Topic:How to open programmatically my Preference Page?
Current Time: Mon May 12 04:54:34 EDT 2025
Powered by FUDForum. Page generated in 0.29317 seconds
