Home » Eclipse Projects » Plugin Development Environment (PDE) » Need help with 'menus' extension
Need help with 'menus' extension [message #16380] Fri, 15 August 2008 23:41 Go to next message
I'm having trouble using the newer 'menus' extension. I have a toolbar
menu contribution and command with a default handler. How do I enable and
disable the toolbar button based some state of the view? I figure this
should be simple and I've tried many things but have had no success. Can
someone post a simple example please?
Re: Need help with 'menus' extension [message #16936 is a reply to message #16380] Sun, 17 August 2008 18:35 Go to previous messageGo to next message
Anyone?
> and disable the toolbar button based some state of the view? I figure
> this should be simple and I've tried many things but have had no
> success. Can someone post a simple example please?
Re: Need help with 'menus' extension [message #17219 is a reply to message #16380] Tue, 19 August 2008 06:40 Go to previous messageGo to next message
Originally posted by: nick.allen.onlinehome.de
Just noticed you are having the same problem as me. It seems there is no
easy way to do what we want. I found this possible solution but have not
been able to get it to work because noone will tell me how to get the
IHandlerService so I can register my own enabled expression for a
command handler. Let me know if you get anywhere though....
Possible solution I found:
if you only want your handler to be active when you conditions are met,
you can use handlerService.activateHandler("command.id", myHandler,
myExpression) to provide a programmatic core expression. It is just a
subclass of Expression.
Expression expression = new Expression() {
public void collectExpressionInfo(ExpressionInfo info) {
info.addVariableNameAccess(ISources.ACTIVE_CURRENT_SELECTION _NAME);
public EvaluationResult evaluate(IEvaluationContext context)
throws CoreException {
Object o = context
.getVariable(ISources.ACTIVE_CURRENT_SELECTION_NAME);
if (o instanceof IStructuredSelection) {
// work with your selection and return TRUE
return EvaluationResult.FALSE;
Re: Need help with 'menus' extension [message #19773 is a reply to message #16380] Sat, 06 September 2008 11:45 Go to previous message
Hopefully you've worked this out already, but here are some ideas -
although I've only used this for menu items (main or popup) I suppose it
will work for toolbar buttons.
First, you need to remove your default handler and configure it as a
handler for your command under the org.eclipse.ui.handlers extension
point. Default handlers are enabled/active by, err, default.
Once you have the handler defined (configured with your command id and
handler class) you can use the elements under handler to configure when
it is active and/or enabled with activeWhen and enabledWhen elements.
If you only have one handler for your command id, then the two elements
are probably interchangeable, but the docs for the
org.eclipse.ui.handlers extension point do a decent job of explaining
the difference.
What conditions you specify depends on what you want to use to trigger
the button to be enabled/disabled. For example, I often use the same
command id for multiple handlers (e.g. reusing a "built in" command like
org.eclipse.ui.edit.delete) and activating the appropriate handlers
based on the item that is selected in one of my views. For that, I use
something like the following:
<extension
point="org.eclipse.ui.handlers">
<handler
class="org.s3xplorer.ui.handlers.BucketDeleteHandler"
commandId="org.eclipse.ui.edit.delete">
<activeWhen>
<iterate
ifEmpty="false"
operator="and">
<instanceof
value="org.jets3t.service.model.S3Bucket">
</instanceof>
</iterate>
</activeWhen>
</handler>
<handler
class="org.s3xplorer.ui.handlers.ObjectDeleteHandler"
<activeWhen>
<iterate
ifEmpty="false"
operator="and">
<instanceof
value="org.jets3t.service.model.S3Object">
</instanceof>
</iterate>
</activeWhen>
</handler>
</extension>
This activates the BucketDeleteHandler if one or more S3Bucket objects
are selected in the active part, and the ObjectDeleteHandler if one or
more S3Object objects are selected (both listed in table viewers in two
different views). There are a bunch of tests you can apply just using
XML - I'm not familiar with many of them, and I find the documentation
to be somewhat lacking, but with some trial and error hopefully you can
work something out.
You can also specify conditions which check properties which you
implement in code. You can create a subclass of
org.eclipse.core.expressions.PropertyTester:
public class ObjectListViewPropertyTester extends PropertyTester {
public boolean test(Object receiver, String property, Object[] args,
Object expectedValue) {
ObjectListView view = (ObjectListView) receiver;
if ("isBucketSelected".equals(property)) {
return view.getBucket() != null;
return false;
Define this under the org.eclipse.core.expressions.propertyTesters
extension point:
<extension
point="org.eclipse.core.expressions.propertyTesters">
<propertyTester
class=" org.s3xplorer.ui.propertytesters.ObjectListViewPropertyTeste r "
id="org.s3xplorer.ui.propertytesters.objectlistview"
namespace="org.s3xplorer.ui.views.ObjectListView"
properties="isBucketSelected"
type="org.s3xplorer.ui.views.ObjectListView">
</propertyTester>
</extension>
And then use this in your handler definition:
<handler
class="org.s3xplorer.ui.handlers.ObjectUploadHandler"
commandId="org.s3xplorer.ui.commands.uploadobject">
<enabledWhen>
<or>
<iterate
ifEmpty="false"
operator="and">
<instanceof
</instanceof>
</iterate>
<with
variable="activePart">
<test
property="org.s3xplorer.ui.views.ObjectListView.isBucketSelected ">
</test>
</with>
</or>
</enabledWhen>
</handler>
The activePart variable used above is defined in org.eclipse.ui.ISources
as ACTIVE_PART_NAME - there are more variable you can use (I suppose
there may be a way to define your own).
Well, hopefully this gives you some ideas - if nothing else I'll have
somewhere to refer to when I forget all this in the near future!
Mark
Re: Need help with 'menus' extension [message #576655 is a reply to message #16380] Sun, 17 August 2008 18:35 Go to previous message
Anyone?
Re: Need help with 'menus' extension [message #577043 is a reply to message #16380] Tue, 19 August 2008 06:40 Go to previous message
Object o = context
Re: Need help with 'menus' extension [message #578822 is a reply to message #16380] Sat, 06 September 2008 11:45 Go to previous message
the difference.
<extension
<handler
<activeWhen>
<iterate
ifEmpty="false"
operator="and">
<instanceof
</instanceof>
</iterate>
</activeWhen>
</handler>
<handler
<activeWhen>
<iterate
ifEmpty="false"
operator="and">
<instanceof
</instanceof>
</iterate>
</activeWhen>
</handler>
</extension>
work something out.
return false;
extension point:
<extension
<propertyTester
</propertyTester>
</extension>
<handler
<enabledWhen>
<or>
<iterate
ifEmpty="false"
operator="and">
<instanceof
</instanceof>
</iterate>
<with
<test
</test>
</with>
</or>
</enabledWhen>
</handler>
Mark
Previous Topic:Eclipse PDE creates invalid zip files that can't be installed
Next Topic:How to enable or disable an action based on the kind of selection?
Current Time: Sun Aug 31 09:32:20 EDT 2025
Powered by FUDForum. Page generated in 0.04566 seconds
