Home » Archived » Albireo » What about SWTSwing and Eclipse on Swing
What about SWTSwing and Eclipse on Swing [message #1368] Sat, 18 August 2007 07:39 Go to next message
Hello all
I was wondering how the Albireo project relates to the work that has been
done on SWTSwing and Eclipse on Swing?
http://eos.sourceforge.net/
http://swtswing.sourceforge.net/main/index.html
It would be great if the work that has been done there could also be
incorporated into Eclipse, in addition to improving the SWT_AWT bridge.
Albert Strasheim
Re: What about SWTSwing and Eclipse on Swing [message #1375 is a reply to message #1368] Mon, 20 August 2007 10:51 Go to previous message
Well, there are (at least) three approaches to the general problem.
1) Create a port of SWT on top of Swing (SWTSwing and EOS)
2) Create a port of Swing on top of SWT (SwingWT)
3) Build on the SWT/AWT bridge so that apps on both toolkits can coexist
better (Albireo)
All three approaches have their merits. For me, the advantage of option
3 is that we:
* Keep the benefits of the native widgets from SWT for most of the
application while still using Swing where it is necessary.
* Don't need to modify the Swing components at all
So, that's why option 3 is the right choice for many applications. The
Albireo proposal was written with those requirements in mind. That's not
to say that the other options aren't the right choice in other cases.
As to whether Albireo should also include work on option 1 and/or 2 as
well as option 3... I suppose it could, but what would be the benefits
to combining the efforts? I don't see any obvious synergy among the
different approaches. But I'm curious to hear what others think...
Albert Strasheim wrote:
> Hello all
> been done on SWTSwing and Eclipse on Swing?
> Albert Strasheim
Re: What about SWTSwing and Eclipse on Swing [message #572163 is a reply to message #1368] Mon, 20 August 2007 10:51 Go to previous message
better (Albireo)
3 is that we:
> Hello all
> Albert Strasheim
Previous Topic:What about SWTSwing and Eclipse on Swing
Next Topic:Layout Constraints
Current Time: Fri Jul 18 23:25:21 EDT 2025
Powered by FUDForum. Page generated in 0.03300 seconds
