project-info question? [message #16369] |
Thu, 20 April 2006 18:04  |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
I was directed here by someone else because I had some questions about
the project-info.xml. I'm not sure if this is the right place though. If
not please redirect me.
> I just created VE's project-info file. I have questions about it.
> When I go to
> http://www.eclipse.org/projects/roadmap/project.php?project= tools.ve
> * It doesn't show the releases on this web page. This is an example
> of what the releases elements look like in the xml.
> <releases>
> <release>
> <name>0.5.0</name>
> <date>12/2003</date>
<download> http://archive.eclipse.org/tools/ve/downloads/drops/R-0.5.0- 200312051712/index.html</download>
> <status>completed</status>
> </release>
> <release> ...
> * I have something like this for the cvs elements. But it only shows
> the first module, and the link above it only goes to the first
> module. The example project-info that I used to create this had
> multiple paths in it:
> <cvs repository="/cvsroot/tools/">
> <module path="org.eclipse.ve" />
> <module path="org.eclipse.ve.cde" />
> <module path="org.eclipse.ve.doc" />
> * The mailing list and newsgroup sections on that page have no links
> on them. It just lists the mailing list and the newsgroup names
> and that is it. I have the maillist and newsgroup files in the
> project-info directory but it isn't using them to describe them.
> Is this page not showing this info?
> * When does the dashboard data get updated? Does it use the
> project-info.xml file for that? The dashboard for VE is currently
> empty even though there are bugs and newsgroup and mailing list
> entries done in the last week.
Rich Kulp
Re: project-info question? [message #16945 is a reply to message #16917] |
Fri, 05 May 2006 12:03  |
I opened for you:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=140389
>> links
> I'm not clear on what you're saying - could you file a bug and I'll
> trace it down?
> - Bjorn
Rich Kulp
Re: project-info question? [message #569057 is a reply to message #16369] |
Wed, 03 May 2006 02:22  |
Rich,
Yes, this is a current known limitation. I suppose there should be a bug
in the system about this.
trace it down?
Once a day.
I see that VE now has data on the dashboard, so I'm going to guess that
the problem has vanished due to the passage of time.
- Bjorn
Re: project-info question? [message #569093 is a reply to message #16917] |
I opened for you:
>> links
> trace it down?
> - Bjorn
Rich Kulp
FUDForum. Page generated in 0.03537 seconds
