installation problem : Java missing in file->new->project [message #172803] |
Sat, 20 December 2003 17:09  |
Originally posted by: r.h.los.wanadoo.nl
I am a newby to eclipse and was triggered by an article in a German
magazine. Downloaded the installation "eclipse-platform-3.0M6-win32.zip" and
"eclipse-SDK-3.0M6-win32.zip" and unziped them to d:\eclipse. I already had
a working java 1.4.2 on my system downloaded from Sun as "Sun ONE studio 4
CE".
When going through the FAQ the first thing I wanted to do was get a simple
"hello world java" programme running to learn how eclipse works. It went
wrong immediately in the beginning. When selecting the menu
file->new->project a window with 2 panes appear with in the left side only a
folder called "simple" is available and on the right side the word "Project
with a wand is visible. Probably I did something wrong with the installation
or have not configured Java in the right way. I could not select a java type
of project.
What went wrong?
regards
Robert Los
Re: installation problem : Java missing in file->new->project [message #174268 is a reply to message #173416] |
Sun, 28 December 2003 15:57  |
Dear David,
I did download the right file "eclipse-SDK-3.0M6-win32.zip". Deleting the
'eclipse' directory and unpacking the zip file again solved the problem.
When i originally installed eclipse I had already a working sun-step one
java environment. When eclipse did not start properly I deleted this SUN
environment and all other related java things, downloaded java sdk again
from the sun website and reinstalled eclipse.
thanks
"David Buttler" <buttler1@llnl.gov> wrote in message
news:bs9upg$8ol$1@eclipse.org...
> Robert Los wrote:
> > Hi,
and
had
4
> > CE".
simple
only a
"Project
installation
type
> > of project.
> > What went wrong?
> > regards
> > Robert Los
> You probably used the wrong download of eclipse. You want the
> "eclipse-SDK-3.0M6-win32.zip" version
> Once you have unzipped that into a new directory and started it there
> are two things you can do:
> 1) open the Java Perspective (click on the little window icon with a
> plus superimposed on it on the left side of the screen, or select
> "Window->Open Perspective->Java" from the menu) Then with the Java
> perspective open, click on the new project icon (on the top beside the
> new package and new class icons)
> 2) Go to File->new->project on the menu. It will open up a dialog that
> will let you select a project type. You should see 3 different project
> types: 1) Java, 2) Plugin development, 3) Simple. Choose the Java
> project. If you don't see the three options you have downloaded the
> wrong zip file from eclipse.org
> Hope this helps,
> Dave
FUDForum. Page generated in 0.04642 seconds
