Home » Modeling » GMF (Graphical Modeling Framework) » Box-in-Box view for compartment
Box-in-Box view for compartment [message #172789] Mon, 18 February 2008 09:43 Go to next message
Hello all,
I have requirement where we are required to display recursively the
compartment contaning the nodes which has child compartment with
node..something like a treeViewer
I would like to display compartments in Box-in-Box view appraoch
| comp1 |
| |------comp2------------| |
| | |comp3| |comp4| | |
| | |comp5| | |
Please let me know what is best approach to achieve this ? Or is there any
better layout for recursive compartment?
Regrads
BG
Re: Box-in-Box view for compartment [message #172826 is a reply to message #172789] Mon, 18 February 2008 11:33 Go to previous messageGo to next message
Hello BG,
Just Define NodeMapping containing ChildReference referensing this NodeMapping
as "referencedChild".
Another way to visualize tree-like structure is by using "Visualize containments
as links" GMF feature: http://www.eclipse.org/gmf/new/gmf-new-1.0.php
Alex Shatalin
Re: Box-in-Box view for compartment [message #172866 is a reply to message #172826] Mon, 18 February 2008 22:38 Go to previous messageGo to next message
Hello Mr Shatalin,
Thanks for reply,I am following the same " Endless/recursive hierarchies"
the output also appearing fine.But it appears as stack one over the other
Rather i would it to be something similar
"http://www.eclipse.org/gmf/new/gmf-new-1.0.php" .Mindmap example .To
achive this what layout do i need to choose ?.As i have nested hireachy
upto 10(Compartments).I tried with ListCompartmentEditPart, it comes in
row ...
Cuurently iam using the ShapeCompartmentEditPart....? Do i need write some
editpolices or do i need createFigure method ResizableCompartmentFigure
result = (ResizableCompartmentFigure) super.createFigure()........;.
Also i have another query.
When i tried to pull a box [element] from one compartment it comes out ?
But same thing doesn't happen the Mindmap example ?
Re: Box-in-Box view for compartment [message #172904 is a reply to message #172866] Tue, 19 February 2008 05:41 Go to previous messageGo to next message
Hello BG,
In this example sub-nodes probably were manually layed-out.
> in row ...
That was my suggestion.
You should probably take care on layout process (popup menu/Arrange all)
I think the reason is: in your model corresponding nodes can be created on
top of diagram.
AFAIR it is not possible to change this behavior without manual code modification
for now.
Alex Shatalin
Re: Box-in-Box view for compartment [message #172912 is a reply to message #172826] Tue, 19 February 2008 06:48 Go to previous messageGo to next message
hi alex,
this "Visualize containments as links" but I it's not described there
how I can model it?
-stefan
Alex Shatalin wrote:
> Hello BG,
> NodeMapping as "referencedChild".
> containments as links" GMF feature:
> Alex Shatalin
Re: Box-in-Box view for compartment [message #172935 is a reply to message #172912] Tue, 19 February 2008 07:15 Go to previous messageGo to next message
Hello SKuhn,
> how I can model it?
Just leave TopNodeReference.containmentFeature blank and use this containment
feature to define reference-only link.
Alex Shatalin
Re: Box-in-Box view for compartment [message #172979 is a reply to message #172904] Tue, 19 February 2008 11:08 Go to previous messageGo to next message
Hello Mr Shatalin,
Iam now using the ArrangeAll request to arrange the compartments
i.e
ArrangeRequest arrangeRequest = new
ArrangeRequest(ActionIds.ACTION_ARRANGE_ALL);
//DiagramEditor diagramEditor1 = (DiagramEditor)
getActEditorPart();
DiagramEditPart diagramEditPart =
diagramEditor.getDiagramEditPart();
SelectInDiagramHelper.activateDiagram(diagramEditPart.getDia gramView());
List<?> l = diagramEditPart.getChildren();
Command arrangeCmd = diagramEditPart.getCommand(arrangeRequest);
arrangeCmd.execute();
But is just arranging the first compartment. Is does not arrange the inner
compartments.
I want something similar to happen like combination of
"selectall/arrangeall".How can i achieve this ?.
BG
Re: Box-in-Box view for compartment [message #173237 is a reply to message #172935] Thu, 21 February 2008 03:54 Go to previous messageGo to next message
Originally posted by: kamesh.sampath.gmail.com
Hi Alex,
I have a tricky situation in modelling and desinging Parent - Child
relationship.
The root of my model has the 1-1 containment reference with Type A, it
cant hold Type B and Type C.
"Type A" which shares 1-* containment reference with "Type B" and "Type B"
has 1-* containment reference with "Type C"
I dont want the Box in Box view depicting the "Type B" - "Type C"
relationship , i want them to be depicted as links.
The idea is to have OpenDiagram bevahior for "Type A" and within that I
will model elements "Type B" and "Type C" as separate diagram elements and
use links to connect "Type B" and "Type C"
Is this possible to achieve this in GMF and depicted diagramatically ?? If
yes can you provide some insight to it or any pointers will help.
Reagrds,
Kamesh
Re: Box-in-Box view for compartment [message #173302 is a reply to message #173237] Thu, 21 February 2008 06:53 Go to previous messageGo to next message
Hello Kamesh,
Try modeling Type B -> Type C containment as a link, but you can face some
future problems. It definitely works then diagram element (Type A) can not
contain "phantom" node (Type C) but you can see some propbelms in your situation.
I suggest you to try it and then fix an errors in generated code.
Alex Shatalin
Re: Box-in-Box view for compartment [message #173322 is a reply to message #173302] Thu, 21 February 2008 07:25 Go to previous messageGo to next message
Hi Alex,
Whats the problems that could potentially occur ? Can you please explain
wht are they ?
Whats the best practice in this situation to model this kind of
relationships so that we can express it neatly in the GMF.
-Kamesh
Re: Box-in-Box view for compartment [message #173344 is a reply to message #173322] Thu, 21 February 2008 07:36 Go to previous messageGo to next message
Hello Kamesh,
I suppoose destination Type B instance to jump into resource root on deleting
the link representing containment.
You can face some other problems - I never tested this situation myself.
Feel free to file a bugzill arequests to correct these issues.
Alex Shatalin
Re: Box-in-Box view for compartment [message #173465 is a reply to message #173344] Thu, 21 February 2008 10:32 Go to previous messageGo to next message
Hi Alex,
Got it ! let me try the same and let the group know about the issues.
Kamesh
"Alex Shatalin" <vano@borland.com> wrote in message
news:3c3172e61e4d48ca42a5de823f16@news.eclipse.org...
> Hello Kamesh,
> deleting the link representing containment. You can face some other
> Alex Shatalin
Re: Box-in-Box view for compartment [message #173480 is a reply to message #173344] Thu, 21 February 2008 12:31 Go to previous messageGo to next message
Hi Alex,
I am now terribly confused, how am suppose to define the Containment as
Links.
I have attached the Models for your reference - the link part is dirty (
where the confusion exists)
Can you please clarify the Containment Links in this context . I am not able
to follow how to do it from the newgroups post .
I hope we can then post it as an article in the GMF Wiki to help others like
me.
Please let me know am doing something wrong or is there a trouble with my
model.
Kamesh
> Hello Kamesh,
> deleting
> Alex Shatalin
Re: Box-in-Box view for compartment [message #175424 is a reply to message #173480] Tue, 04 March 2008 05:59 Go to previous message
Hello Kamesh,
you have to:
1. Stecify 2 top-level nodes for "State", "City" leaving "containmentFeature"
blank
2. Create 2 link mappings with "targetFeature"s set to: "states", "cities"
As a result you should be able to:
- create new Countries on diagram
- create new States on diagram and connect existing Countries with newly
created States by first type of the link
- create new Cities on the diagram and connect existing States with newly
creates Cities by second type of the link
Alex Shatalin
Previous Topic:FlowLayout for NonContainmentFeature in Compartment
Next Topic:Generated GMF Property Sheet problem, editor embedded in multipage editor.
Current Time: Fri Nov 07 18:03:12 EST 2025
Powered by FUDForum. Page generated in 0.07504 seconds
