Eclipse 3.2 for solaris sparc crash at startup [message #172674] |
Wed, 27 September 2006 05:41 |
mikael petterson Messages: 73 Registered: July 2009 |
Member |
When I try to start Eclipse 3.2.0 solaris sparc version I get the
following error ( see below). Any ideas what it could be?
cheers,
//mikael
bash-2.03$ /app/eclipse/3.2/eclipse
** (Eclipse:27574): WARNING **: Couldn't load font "adobe-courier Bold 14"
falling back to "Sans Bold 14"
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : 11 occurred at PC=0xDF915564
Function=gtk_tooltips_force_window+0xB8
Library=/usr/lib/libgtk-x11-2.0.so.0
Current Java thread:
org.eclipse.swt.internal.gtk.OS._gtk_tooltips_force_window(N ative Method)
org.eclipse.swt.internal.gtk.OS.gtk_tooltips_force_window(OS .java:6687)
at org.eclipse.swt.widgets.Shell.setToolTipText(Shell.java:1652 )
org.eclipse.swt.widgets.ToolItem.setToolTipText(ToolItem.jav a:1010)
org.eclipse.swt.widgets.ToolItem.setToolTipText(ToolItem.jav a:1004)
org.eclipse.jface.action.ActionContributionItem.update(Actio nContributionItem.java:720)
org.eclipse.jface.action.ActionContributionItem.fill(ActionC ontributionItem.java:330)
org.eclipse.jface.action.ToolBarManager.update(ToolBarManage r.java:317)
org.eclipse.jface.action.ToolBarManager.createControl(ToolBa rManager.java:101)
org.eclipse.jface.action.ToolBarContributionItem.fill(ToolBa rContributionItem.java:190)
org.eclipse.jface.action.CoolBarManager.update(CoolBarManage r.java:919)
org.eclipse.jface.action.CoolBarManager.createControl(CoolBa rManager.java:244)
org.eclipse.jface.internal.provisional.action.CoolBarManager 2.createControl2(CoolBarManager2.java:76)
org.eclipse.jface.window.ApplicationWindow.createCoolBarCont rol(ApplicationWindow.java:513)
org.eclipse.ui.internal.WorkbenchWindow.createDefaultContent s(WorkbenchWindow.java:952)
org.eclipse.ui.internal.WorkbenchWindowConfigurer.createDefa ultContents(WorkbenchWindowConfigurer.java:610)
org.eclipse.ui.application.WorkbenchWindowAdvisor.createWind owContents(WorkbenchWindowAdvisor.java:267)
org.eclipse.ui.internal.WorkbenchWindow.createContents(Workb enchWindow.java:898)
at org.eclipse.jface.window.Window.create(Window.java:426)
org.eclipse.ui.internal.Workbench.doRestoreState(Workbench.j ava:2836)
at org.eclipse.ui.internal.Workbench.access$14(Workbench.java:2 805)
at org.eclipse.ui.internal.Workbench$19.run(Workbench.java:1681 )
org.eclipse.ui.internal.Workbench.runStartupWithProgress(Wor kbench.java:1421)
org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1679)
at org.eclipse.ui.internal.Workbench.access$12(Workbench.java:1 650)
at org.eclipse.ui.internal.Workbench$17.run(Workbench.java:1529 )
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1473)
org.eclipse.ui.internal.WorkbenchConfigurer.restoreState(Wor kbenchConfigurer.java:183)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:702)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1085)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1847)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Dynamic libraries:
0x10000 /app/jdk/1.4.2_08/bin/java
0xff350000 /usr/lib/libthread.so.1
0xff340000 /usr/lib/libdl.so.1
0xff200000 /usr/lib/libc.so.1
0xff390000 /usr/platform/SUNW,Sun-Fire-V440/lib/libc_psr.so.1
0xfe000000
/afs/research.ericsson.se/cells/sunrise.ericsson.se/app/jdk/ .sys/@sys/1.4.2_08/jre/lib/sparc/client/libjvm.so
0xff2d0000 /usr/lib/libCrun.so.1
0xff1e0000 /usr/lib/libsocket.so.1
0xff100000 /usr/lib/libnsl.so.1
0xff0d0000 /usr/lib/libm.so.1
0xff1c0000 /usr/lib/libsched.so.1
0xff0b0000 /usr/lib/libmp.so.2
0xff060000
/afs/research.ericsson.se/cells/sunrise.ericsson.se/app/jdk/ .sys/@sys/1.4.2_08/jre/lib/sparc/native_threads/libhpi.so
0xff020000
/afs/research.ericsson.se/cells/sunrise.ericsson.se/app/jdk/ .sys/@sys/1.4.2_08/jre/lib/sparc/libverify.so
0xfe7c0000
/afs/research.ericsson.se/cells/sunrise.ericsson.se/app/jdk/ .sys/@sys/1.4.2_08/jre/lib/sparc/libjava.so
0xfe7a0000
/afs/research.ericsson.se/cells/sunrise.ericsson.se/app/jdk/ .sys/@sys/1.4.2_08/jre/lib/sparc/libzip.so
0xfe610000 /usr/lib/locale/en_US.ISO8859-1/en_US.ISO8859-1.so.2
0xfe430000
/afs/research.ericsson.se/cells/sunrise.ericsson.se/app/jdk/ .sys/@sys/1.4.2_08/jre/lib/sparc/libnet.so
0xfdf60000
/afs/research.ericsson.se/cells/sunrise.ericsson.se/app/jdk/ .sys/@sys/1.4.2_08/jre/lib/sparc/libnio.so
0xfdf40000 /usr/lib/librt.so.1
0xfdf20000 /usr/lib/libaio.so.1
0xfde60000 /usr/lib/libsendfile.so.1
0xe1010000
/home/eraonel/.eclipse/org.eclipse.platform_3.2.0/configurat ion/org.eclipse.osgi/bundles/223/1/.cp/libswt-pi-gtk-3232.so
0xdf780000 /usr/lib/libgtk-x11-2.0.so.0
0xe13e0000 /usr/lib/libgthread-2.0.so.0
0xe0660000 /usr/openwin/lib/libXtst.so.1
0xe0630000 /usr/lib/libgdk_pixbuf-2.0.so.0
0xdf680000 /usr/lib/libgdk-x11-2.0.so.0
0xdffb0000 /usr/lib/libpango-1.0.so.0
0xe0550000 /usr/lib/libatk-1.0.so.0
0xdfe20000 /usr/lib/libgobject-2.0.so.0
0xdfd60000 /usr/lib/libgmodule-2.0.so.0
0xdf580000 /usr/lib/libglib-2.0.so.0
0xdfd30000 /usr/openwin/lib/libXext.so.0
0xdf480000 /usr/openwin/lib/libX11.so.4
0xdfc60000 /usr/lib/libpangox-1.0.so.0
0xdfd10000 /usr/openwin/lib/locale/common/xlibi18n.so.2
0xdfc20000
/home/eraonel/.eclipse/org.eclipse.platform_3.2.0/configurat ion/org.eclipse.osgi/bundles/223/1/.cp/libswt-gtk-3232.so
0xdf760000 /usr/lib/iconv/UTF-8%8859-1.so
0xdf630000 /usr/openwin/lib/locale/common/ximlocal.so.2
0xdf710000 /usr/lib/pango/1.0.0/modules/pango-basic-x.so
0xdf740000 /usr/lib/gtk-2.0/2.0.100/immodules/im-xim.so
Heap at VM Abort:
Heap
def new generation total 4480K, used 738K [0xe5400000, 0xe5880000,
0xe7070000)
eden space 4352K, 14% used [0xe5400000, 0xe5498b68, 0xe5840000)
from space 128K, 100% used [0xe5840000, 0xe5860000, 0xe5860000)
to space 128K, 0% used [0xe5860000, 0xe5860000, 0xe5880000)
tenured generation total 36416K, used 8913K [0xe7070000, 0xe9400000,
0xf5400000)
the space 36416K, 24% used [0xe7070000, 0xe7924408, 0xe7924600,
0xe9400000)
compacting perm gen total 11776K, used 11730K [0xf5400000, 0xf5f80000,
0xf9400000)
the space 11776K, 99% used [0xf5400000, 0xf5f74808, 0xf5f74a00,
0xf5f80000)
Local Time = Wed Sep 27 07:31:40 2006
Elapsed Time = 17
# The exception above was detected in native code outside the VM
# Java VM: Java HotSpot(TM) Client VM (1.4.2_08-b03 mixed mode)
# An error report file has been saved as hs_err_pid27574.log.
# Please refer to the file for further information.
bash-2.03$ exit
FUDForum. Page generated in 0.07960 seconds
