Home » Archived » BIRT » change chart type via interactivity
change chart type via interactivity [message #172586] Thu, 22 June 2006 08:38 Go to next message
Originally posted by: thomaskr.segue.at
hi,
is it possible to change the chart type via script? e.g i have a bar
chart and want to change it to a pie chart via clicking on the chart area?
another thing, i would need is how to change the orientation of a bar
chart: in the gui there is a "flip axis" check box. changing this via
interactivity as well would be great.
thanks
Re: change chart type via interactivity [message #173409 is a reply to message #172586] Mon, 26 June 2006 09:34 Go to previous messageGo to next message
It depends exactly what is your renderer. If you're using Swing or SWT, yes,
it's possible. If you just visualize the chart in a browser, it's not, as
there is no way now to regenerate the chart on the server, by a browser
request (unless you implement your own servlet to do it).
Assuming you're using SWT/Swing, I would advise you look at the examples in
the chart examples plugin. You will need to create a new type of series in
your chart model, since each type is using different series (that can have
different attributes). For the flip axis, it's only an attribute to change
in the model, so it should be easier.
David
"Thomas Krupa" <thomaskr@segue.at> wrote in message
news:e7e30s$3ef$1@utils.eclipse.org...
> hi,
> is it possible to change the chart type via script? e.g i have a bar chart
> thanks
Re: change chart type via interactivity [message #174006 is a reply to message #173409] Thu, 29 June 2006 02:51 Go to previous message
thanks for your answer,
problem is i visalize the chart in a browser
> David
>> hi,
>> thanks
Previous Topic:How to expand table of contents in default in birt-viewer frameset
Next Topic:ReferenceError: "params" is not defined.
Current Time: Wed Jul 16 01:51:20 EDT 2025
Powered by FUDForum. Page generated in 0.04902 seconds
