Home » Language IDEs » Java Development Tools (JDT) » CompilationUnitDocumentProvider.java
CompilationUnitDocumentProvider.java [message #172247] Sat, 07 August 2004 08:12 Go to next message
Originally posted by: crscca.bol.net.in
I am creating some code using this:-
IPackageFragment packageFragment = sourceFolder.createPackageFragment(
packageName, true, monitor);
packageFragment.createCompilationUnit("SomeClass.java",
theCodeAsAString, true, monitor);
Sometimes I get this following message( not when I am creating the code
but when I am exitting the runtime workbench in the console):-
Can anyone suggest something? Usually it all works without any issues.
org.eclipse.ui.editors.text.TextFileDocumentProvider.<init>(TextFileDocumentProvider.java:384)
org.eclipse.ui.editors.text.TextFileDocumentProvider.<init>(TextFileDocumentProvider.java:369)
org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitDocume ntProvider. <init>(CompilationUnitDocumentProvider.java:772)
org.eclipse.jdt.internal.ui.JavaPlugin.getCompilationUnitDoc umentProvider(JavaPlugin.java:514)
org.eclipse.jdt.internal.ui.text.JavaCompositeReconcilingStr ategy.getProblemRequestorExtension(JavaCompositeReconcilingS trategy.java:63)
org.eclipse.jdt.internal.ui.text.JavaCompositeReconcilingStr ategy.initialReconcile(JavaCompositeReconcilingStrategy.java :118)
org.eclipse.jface.text.reconciler.MonoReconciler.initialProc ess(MonoReconciler.java:103)
org.eclipse.jdt.internal.ui.text.JavaReconciler.initialProce ss(JavaReconciler.java:304)
org.eclipse.jface.text.reconciler.AbstractReconciler$Backgro undThread.run(AbstractReconciler.java:170)
Re: CompilationUnitDocumentProvider.java [message #172431 is a reply to message #172247] Mon, 09 August 2004 10:01 Go to previous messageGo to next message
Originally posted by: olivier_thomannNO.ca.ibm.comSPAM
Le Sat, 7 Aug 2004 12:12:06 +0000 (UTC), crscca@bol.net.in (Raster) a
écrit :
>java.lang.NullPointerException
> at
>org.eclipse.ui.editors.text.TextFileDocumentProvider.<init >(TextFileDocumentProvider.java:384)
Are you sure that this runs in an Eclipse workbench? The line 384 is:
fResourceRuleFactory=
ResourcesPlugin.getWorkspace().getRuleFactory();
So I would say that that the ResourcesPlugin.getWorkspace() returns
null.
Olivier
Re: CompilationUnitDocumentProvider.java [message #172860 is a reply to message #172431] Wed, 11 August 2004 03:06 Go to previous message
Sounds logical.
So what does this mean?
Let me reproduce my error and see.
Must be some bug in my code I guess. maybe under some condition I am using
a sourcefolder or something which does not have a workspace somehow.
Let me check.
Thanks.
> écrit :
> > at
> null.
> Olivier
Previous Topic:Auto Complete
Next Topic:Only compile classes accessible from the main class?
Current Time: Tue Jul 22 14:47:38 EDT 2025
Powered by FUDForum. Page generated in 0.05031 seconds
