Home » Language IDEs » Java Development Tools (JDT) » Eclipse Features missing
Eclipse Features missing [message #171882] Wed, 04 August 2004 14:57 Go to next message
Originally posted by: eclipse20040804.schwager.com
First I want to say, "Thanks for an awesome IDE. It has helped me turn
the corner from a frightened Java newbie to a frightening code-crunching
machine!"
I am wondering about a couple of features in Eclipse. First, in older
3.0-betaish versions I was able to set keyboard preferences for the "run"
function. This enabled me to start a couple of packages without having to
resort to the mouse. It was very fast. While there is still a way to run
the last project from the keyboard, your basic "run" is no longer
keyboard-operational. Can this be returned?
Also, Eclipse .java editing windows under Linux/Windows has a white
background, while under Solaris/Motif it is gray. This reduces the
contrast for me, which is a bummer. Can there be a way to set the window
backgrounds? Thanks. This is for 3.0.0, running on Solaris 8 but
displaying to a Solaris 2.5.1 box running OLVWM. (if that makes a
difference)
Thanks!
-Mike Schwager
eclipse20040804@schwager.com (until if/when I start getting spammed at
that address)
Re: Eclipse Features missing [message #171909 is a reply to message #171882] Wed, 04 August 2004 16:21 Go to previous messageGo to next message
You can run/debug from the context menu in the navigator. Use the keyboard
to bring up the context menu (shift-F10 on windows).
Darin
"Michael Schwager" <eclipse20040804@schwager.com> wrote in message
news:cerbic$okl$1@eclipse.org...
> machine!"
> difference)
> Thanks!
> -Mike Schwager
> that address)
Re: Eclipse Features missing [message #171994 is a reply to message #171882] Thu, 05 August 2004 04:10 Go to previous messageGo to next message
Originally posted by: daniel.megert.gmx.net
Michael Schwager wrote:
>Hi,
>machine!"
>backgrounds?
Not sure what you mean by "windows". If you mean the Java editor's
background then you can change it here:
Java Editor: Window > Preferences > Java > Editor - Syntax tab
Dani
>difference)
>Thanks!
>-Mike Schwager
>that address)
Re: Eclipse Features missing [message #172036 is a reply to message #171909] Thu, 05 August 2004 09:32 Go to previous messageGo to next message
Sorry, I don't see it on mine. Nothing with the word "run" in it when I
hit shift-F10. A menu does come up, however. Am I looking at the correct
menu? Things such as "Open Declaration" and "Open Type Heirarchy" are in
there.
In the old days, if I went to
Window->Preferences->Workbench->Keys->Command->Category- >"Run/Debug" then
Click on "Name:" and scroll down, I would see "Run" amongst the others
like "Run Last Launched" and "Run to Line".
"Run" is no longer there...
Thanks for the reply. I appreciate your attention.
Re: Eclipse Features missing [message #172051 is a reply to message #171994] Thu, 05 August 2004 09:34 Go to previous messageGo to next message
That's it! Thanks!
Can I change the background colors on the rest of the IDE? For example,
the "Package..." explorer section on the left hand side? This is less
critical but still useful.
-Mike
Re: Eclipse Features missing [message #172070 is a reply to message #172051] Thu, 05 August 2004 09:54 Go to previous messageGo to next message
>That's it! Thanks!
Sure. This is your OS's widget and therefore you can change colors and
font directly in your OS (e.g. .Xdefaults file under Linux).
Dani
>-Mike
Re: Eclipse Features missing [message #172086 is a reply to message #172036] Thu, 05 August 2004 10:24 Go to previous message
The category is now (3.0) called "Run/Debug", and contains "Run Last
Launched", etc.
Darin
news:cetct3$n9e$1@eclipse.org...
keyboard
> there.
Previous Topic:how to see if Java Source menu is enabled
Next Topic:Can Show Declaration go straight to the Impl. of an Interface?
Current Time: Fri Jul 18 02:01:07 EDT 2025
Powered by FUDForum. Page generated in 0.04863 seconds
