Home » Newcomers » Newcomers » can I define body content of auto generated method?
can I define body content of auto generated method? [message #171693] Wed, 20 September 2006 02:41 Go to next message
Originally posted by: justfly.shi.gmail.com
the default body content is "return null", can i configurate in any where to
make the default body content to be "throw new
UnsupportedOperationException();"
Re: can I define body content of auto generated method? [message #171849 is a reply to message #171693] Wed, 20 September 2006 13:15 Go to previous messageGo to next message
Open the preferences window and enter "code templates" into the filter
field at the top. That will highlight the Java code templates settings.
I think the one you want to edit is "Method body"
Hope this helps,
Eric
Re: can I define body content of auto generated method? [message #172093 is a reply to message #171849] Thu, 21 September 2006 22:25 Go to previous message
It works, thank you very much!
"Eric Rizzo" <eclipse4@rizzoweb.com>
??????:eersk7$1j7$1@utils.eclipse.org...
>> to make the default body content to be "throw new
> field at the top. That will highlight the Java code templates settings. I
> Hope this helps,
> Eric
Previous Topic:How to compile and build eclipe
Next Topic:Eclipse's compatibility policy
Current Time: Fri Jul 25 00:42:33 EDT 2025
Powered by FUDForum. Page generated in 0.11589 seconds
