Home » Eclipse Projects » Plugin Development Environment (PDE) » NoClassDefFoundError when accessing libraries in the JRE's ext folder
NoClassDefFoundError when accessing libraries in the JRE's ext folder [message #16239] Wed, 13 August 2008 09:27 Go to next message
Originally posted by: tom.seidel.spiritlink.de
I have a small problem with the security extension that are shipped by
the jdk. In general it's not possible to use classes which are located
in the sun/security package, so I created an access rule which grants
the bundle access to the related classes.
If I want to launch my RCP, I get the following runtime error:
java.lang.NoClassDefFoundError: sun/security/pkcs11/SunPKCS11
although the sunpkcs11.jar is located under the JRE System Library Build
Path Entry.
Does anybody know what I'm missing?
Thanks in advance,
Tom
Re: NoClassDefFoundError when accessing libraries in the JRE's ext folder [message #16281 is a reply to message #16239] Wed, 13 August 2008 12:23 Go to previous messageGo to next message
Ok, found it. It's more an OSGi classloading issue
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=30919)
Tom Seidel schrieb:
> Path Entry.
> Thanks in advance,
> Tom
Re: NoClassDefFoundError when accessing libraries in the JRE's ext folder [message #576297 is a reply to message #16239] Wed, 13 August 2008 12:23 Go to previous messageGo to next message
Tom Seidel schrieb:
> Path Entry.
> Thanks in advance,
> Tom
Re: NoClassDefFoundError when accessing libraries in the JRE's ext folder [message #639300 is a reply to message #576297] Mon, 15 November 2010 18:55 Go to previous message
Hi Tom,
I'm also trying to use the SunPKCS11 class in my plugin, and experiencing the same problem. I read through the issue that you mentioned:
. . . but I'm still not sure what the actual solution is. Can anybody summarize what it is I need to do to use a class from the sun.security.pkcs11 package in my plugin?
Thanks!
Steve
Previous Topic:documentation on "org.eclipse.pde.core.BinaryRepositoryProvider"
Next Topic:No .eclipseproduct after build
Current Time: Sun Aug 31 21:04:54 EDT 2025
Powered by FUDForum. Page generated in 0.08940 seconds
