Home » Archived » BIRT » Date Report Parameters only work in designer
Date Report Parameters only work in designer [message #171669] Tue, 20 June 2006 10:01 Go to next message
Originally posted by: Barrysan.hotmail.com
I have created some report parameters of type "DateTime". I can provide it
a default value of something like "01/01/2006" and it works good if I
preview the design. But if I use the BIRT web viewer and pass the exact
same value to it, or any other date value, it says "The value "01/01/2006"
is invalid with the type "dateTime". What might I be doing wrong?
Also, under default value in the Edit Parameter dialog, it says "enter date
values as MM/DD/YYYY hh:mm:ss AM/PM". Where is this configurable in case I
want users to enter a different format?
Re: Date Report Parameters only work in designer [message #171733 is a reply to message #171669] Tue, 20 June 2006 10:56 Go to previous messageGo to next message
Originally posted by: danny.rosenberg.weblayers.com
Ah yes. Definitely one of the less intuitive UIs in BIRT. I think I can
help.
Let's assume for the sake of argument you want to use one of the
"out-of-the-box" date formats. In this example, we'll use Short Date since
it's close to your requested format - 1/1/2006.
Right-click your parameter, and then left-click Edit. Set your default
value to 1/1/2006 (or whatever). Then, believe it or not, you're going to
use the Display As fieldset and click the Change button after "Format string
as:". Select the Short Date format (which today would be 6/20/06), and
click OK. Click OK again.
You could also select a Custom Date format, but the above should get you
started.
best,
-d.
"Barry" <Barrysan@hotmail.com> wrote in message
news:e78rj8$87s$1@utils.eclipse.org...
> date values as MM/DD/YYYY hh:mm:ss AM/PM". Where is this configurable in
> case I want users to enter a different format?
Re: Date Report Parameters only work in designer [message #171741 is a reply to message #171733] Tue, 20 June 2006 12:11 Go to previous message
Wow, I actually considered doing that, then thought, "nah, that won't work,
that's only for displaying."
I will try it out. Thank you for your help.
"Danny Rosenberg" <danny.rosenberg@weblayers.com> wrote in message
news:e79293$ubr$1@utils.eclipse.org...
> help.
> since it's close to your requested format - 1/1/2006.
> string as:". Select the Short Date format (which today would be 6/20/06),
> and click OK. Click OK again.
> started.
> best,
> -d.
Re: Date Report Parameters only work in designer [message #171749 is a reply to message #171741] Tue, 20 June 2006 11:32 Go to previous message
Anytime.
news:e7936e$737$1@utils.eclipse.org...
> work, that's only for displaying."
>> help.
>> to use the Display As fieldset and click the Change button after "Format
>> 6/20/06), and click OK. Click OK again.
>> started.
>> best,
>> -d.
Previous Topic:[JCA] perplex the location of javax.comm.properties
Next Topic:Scripting DS, Custom POJO and Classpath.
Current Time: Sat Jul 26 19:46:50 EDT 2025
Powered by FUDForum. Page generated in 0.03869 seconds
