Debugger No Source Found and src.zip [message #171651] |
Tue, 19 September 2006 21:15 |
Originally posted by: rgants1.aol.com
All,
For the last several hours I have been struggling with a debug issue that
I seemed to have solved but Im not clear why what I did solved my
problem. The situation I was encountering is as follows:
Every time I tried to step through my code (F5) to view variables set in
the watch I would encounter a problem that seemed to point to loading
classes; "Source Not Found".
In short I ended up going to the src.zip and unzipping all seems to work
from a debugger point of view, the question is why? Even though I directed
the "Source Lookup Path:" to the src.zip's home
(/usr/local/jdk1.5.0_08/src.zip). So why did the act of unzipping this
seemingly fix my problem?
What is it that I am missing in setting up my Eclipse environment?
thanks
Bobby
FUDForum. Page generated in 0.07549 seconds
