Home » Language IDEs » Java Development Tools (JDT) » Java5.0/Eclipse3.1 - will all features be supported?
Java5.0/Eclipse3.1 - will all features be supported? [message #171290] Tue, 03 August 2004 11:17 Go to next message
Hi, will Eclipse 3.1 support all the features of Java5.0? If so, is
there a rough schedule, or at least a priority list, of which feature
will be developped first?
Guillaume
SM (subliminal message): annotations annotations annotations...
Re: Java5.0/Eclipse3.1 - will all features be supported? [message #171297 is a reply to message #171290] Tue, 03 August 2004 05:52 Go to previous messageGo to next message
> there a rough schedule, or at least a priority list, of which feature will
> Guillaume
http://www.eclipsepowered.org/archives/2004/07/29/eclipse-31 -draft-plan-released/
should answer all your questions :).
Re: Java5.0/Eclipse3.1 - will all features be supported? [message #171375 is a reply to message #171297] Tue, 03 August 2004 13:53 Go to previous messageGo to next message
Well, re-reading the 3.1 draft plan seems to indicate that all features
will be supported; however I am still curious if there is an internal
plan for java5 support.
>>Guillaume
Re: Java5.0/Eclipse3.1 - will all features be supported? [message #171555 is a reply to message #171375] Tue, 03 August 2004 14:10 Go to previous messageGo to next message
At the base level (jdt core) their plan can be found here (look for the
Cheetah section which is now part of the 3.1 stream):
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/jdt- core-home/r3.0/main.html
You will be able to find similar plans for the other components such as JDT
UI and the support they are adding
HTH
Darins
"Guillaume Pothier" <gpothier@free.fr> wrote in message
news:cenu6k$5it$1@eclipse.org...
will
> >>Guillaume
Re: Java5.0/Eclipse3.1 - will all features be supported? [message #171563 is a reply to message #171555] Tue, 03 August 2004 20:58 Go to previous message
Thanks! For the other readers, replace 3.0 with 3.1 in the url...
g
> HTH
> Darins
> will
>>>>Guillaume
Previous Topic:J ?
Next Topic:[ANN] AdvanQas - advanced quick assists for Java editor
Current Time: Sat Jul 26 10:00:06 EDT 2025
Powered by FUDForum. Page generated in 0.08933 seconds
