Home » Archived » BIRT » Installing BIRT on Sybase's EAServer
Installing BIRT on Sybase's EAServer [message #171025] Fri, 16 June 2006 12:08 Go to next message
Originally posted by: jdobry.berkeley.edu
I have installed the BIRT viewer on Sybase's EAServer 5.2 running under
JDK 1.4.
When I try to run the sample reports or even a report with just a title, I
get the message:
The design file
C:\Sybase\EAServer\Repository\WebApplication\Eclipse_BIRT_Re port_Viewer\report\SalesInvoice.rptdesign
has error and can not be run
Any suggestions would be appreciated.
Judy
Re: Installing BIRT on Sybase's EAServer [message #171162 is a reply to message #171025] Fri, 16 June 2006 16:56 Go to previous messageGo to next message
Originally posted by: doug_porter.dailyaccess.nospam.com
What version of BIRT are you using?
Where did you put the BIRT jar files?
I presume you are using EAServer to run the BIRT web application. Did it generate any errors when deploying the War file or on
server startup?
Doug Porter
DailyAccess Corporation
"Judy Dobry" <jdobry@berkeley.edu> wrote in message news:6ca4027428c96f95d396b46ff8d1a91c$1@www.eclipse.org...
> JDK 1.4.
> get the message:
> The design file
> Judy
Re: Installing BIRT on Sybase's EAServer [message #171438 is a reply to message #171162] Mon, 19 June 2006 13:23 Go to previous messageGo to next message
Originally posted by: jdobry.nospam.berkeley.edu
I'm using Birt Runtime 2.0.1.
I deployed the birt.war file into EAServer so the jars are under
EAServer\Repository\WebApplication\Eclipse_BIRT_Report_Viewe r\WEB-INF\lib.
I added the commons-logging-api.jar to this directory.
I didn't get any error messages when I installed the war file and I don't
get any when I try to display a simple report (the report just has a
title).
Judy
Re: Installing BIRT on Sybase's EAServer [message #171440 is a reply to message #171438] Mon, 19 June 2006 14:37 Go to previous message
I've only used Birt from within a java component in EAServer not from the webserver, but we had to deploy the birt jar files to the
EAServer/java/classes directory to get it to work. I'll try and deploy the war this afternoon and see what happens on our servers.
Doug Porter
"Judy Dobry" <jdobry@nospam.berkeley.edu> wrote in message news:ee766213acffe0469d17eeaa272caac6$1@www.eclipse.org...
> title).
> Judy
Previous Topic:Improved RCP integration with BIRT
Next Topic:Problem with Javascript
Current Time: Wed Jul 16 21:17:51 EDT 2025
Powered by FUDForum. Page generated in 0.07590 seconds
