Home » Eclipse Projects » GEF » Connections between Editors
Connections between Editors [message #170799] Mon, 07 March 2005 10:15 Go to next message
Originally posted by: a.morgan.pilz.ie
Hey,
My problem is as follows. I have 2 types of object a Box and a Container.
A Box can be connected to another Box.
A Container contains zero to many Boxes.
When a Box is in a Container it appears smaller as the zoom on the Container
is set to 50%, this is so I can fit more in there.
A Box maintains its connections even when moved into a Container (or back
out again)
When I double-click a Container I open a new editor which shows just the
contents of the Container.
If two Boxes in a Container are connected then these connections are shown
fine in the new Container editor.
However the problem occurs if I have a Box inside the Container connected to
a Box outside the Container.
In this case when I open the Container editor the connection had no endpoint
as the Box that it was connected to is not shown.
So I need to find a way around this problem.
I was thinking that if I had a connection that had no Box on the end in the
Container editor then I could create some kind of temporary or marker figure
just to signify the fact that there is a connection to something outside the
current Container/Editor.
Anybody had any experience with anything like this or got any ideas on how
this could be achieved ?
Alan.
Re: Connections between Editors [message #170855 is a reply to message #170799] Mon, 07 March 2005 22:47 Go to previous messageGo to next message
When a box is not visible, maybe the line can be connected to the container
instead, with some marker (i.e., decoration) indicating that the connection
is actually connected to something inside that container.
"Alan Morgan" <a.morgan@pilz.ie> wrote in message
news:d0hr70$g2h$1@www.eclipse.org...
> Hey,
> Container
> out again)
> to
> endpoint
> the
> figure
> the
> Alan.
Re: Connections between Editors [message #170995 is a reply to message #170855] Tue, 08 March 2005 05:47 Go to previous messageGo to next message
Hi Pratik,
Yes I was thinking along the same lines.
Its the "where to start" that is catching me.
What I was thinking was that if the Box wasn't visible and therefore the
Connection had no target then I could catch some kind of event or something
to signify this.
Any thoughts ?
Alan.
"Pratik Shah" <ppshah@us.ibm.com> wrote in message
news:d0j75i$u3$1@www.eclipse.org...
container
connection
> > Hey,
Container.
> > Container
back
> > out again)
shown
connected
> > to
> > endpoint
> > the
> > figure
> > the
how
> > Regards,
> > Alan.
Re: Connections between Editors [message #171053 is a reply to message #170799] Tue, 08 March 2005 17:01 Go to previous message
Originally posted by: Lamont_Gilbert.rigidsoftware.com
Alan Morgan wrote:
> Hey,
> out again)
> Alan.
You have an edit part factory used by your comtainer editor return a
special 'connection' edit part. That 'connection' edit part should know
if its connected to a box which is not within the editor, and draw
itself accordingly, or not at all.
Previous Topic:Drag-and-drop on Motif
Next Topic:DirectedGraph and Edge.tree field
Current Time: Mon Jul 21 22:10:05 EDT 2025
Powered by FUDForum. Page generated in 0.51233 seconds
