Home » Eclipse Projects » DTP » bug#145157 - Derby Synonym issue
bug#145157 - Derby Synonym issue [message #16158] Sun, 04 June 2006 20:58
When I tried a Debug with breakpoints in all methods of
AbstractContainmentProvider and DerbySynonymContainmentProvider, the
execution didnot stop in any of these. I can understand in case
DerbySynonymContainmentProvider since the folder/group itself is not
appearing in DSE; but what about AbstractContainmentProvider ?
Anthos
Lawrence E Dunnell wrote:
> By the way, my change for
> 145157 will not fix the problem. However,
> I was able to repro this in the debugger and it will require a code
> change.
> Still investigating the solution.
> Larry Dunnell
> Internet address: ledunnel@us.ibm.com
> *jograham@sybase.com*
> Sent by: dtp-pmc-bounces@eclipse.org
> 06/02/2006 05:14 PM
> Please respond to
> DTP PMC mailing list <dtp-pmc@eclipse.org>
> To
> DTP development mailing list <dtp-dev@eclipse.org>
> cc
> dtp-pmc@eclipse.org
> Subject
> [dtp-pmc] Re: [dtp-dev] DTP 0.9 RC5 6/2 2nd build
> Larry,
> Thanks very much for the quick turn around on these issues!
> For 145156, I think the best solution for Callisto is to deliver this
> plug-in unjarred, and then work on the necessary changes later. If the PMC
> agrees, this will just be a simple change to the build process for this
> plug-in.
> John Graham
> Eclipse Data Tools Platform PMC Chair
> Staff Software Engineer, Sybase, Inc.
> http://dataplat.blogspot.com/
> Lawrence E
> Dunnell
> <ledunnel@us.ibm. To
> com> DTP development mailing list
> Sent by: <dtp-dev@eclipse.org>
> dtp-dev-bounces@e cc
> clipse.org dtp-pmc@eclipse.org
> Subject
> 06/02/2006 07:49 build
> PM
> Please respond to
> DTP development
> mailing list
> <dtp-dev@eclipse.
> org>
> The fix 145156 turns out to not be trivial and world require a change to
> the labeService extension point implementation and to all consumers of the
> extension point. The PMC will have to decide whether or not to make
> such a
> change this late in the game. The workaround is to not single-jar the
> plug-in.
> I am unable to repro 145156 in my workspace under the debugger. I did
> notice some issues in the plugin.xml for the
> org.eclipse.datatools.connectivity.derby plug-in and committed the
> changes.
> We'll have to test another build to see if that fixed the problem.
> Larry Dunnell
> Lawrence E
> Dunnell/Redmond/IBM@IBMUS
> Sent by: To
> dtp-dev-bounces@eclipse.org DTP development mailing
> cc
> 06/02/2006 03:48 PM
> Subject
> Please respond to 6/2 2nd build
> I am testing a fix for these two problems. Will deliver soon. It
> looks to
> be a trivial change to plugin.xml.
> Larry Dunnell
> jograham@sybase.com
> Sent by: dtp-dev-bounces@eclipse.org
> To
> 06/02/2006 02:44 PM dtp-dev@eclipse.org
> cc
> Please respond to Subject
> DTP development mailing list [dtp-dev] DTP 0.9
> <dtp-dev@eclipse.org> RC5 6/2 2nd build
> A second build of DTP 0.9 RC5 6/2 is now available on the DTP download
> site. This contains a fix for the problem of synonyms not appearing in the
> Data Source Explorer tree:
> http://dev.eclipse.org/mhonarc/lists/dtp-dev/msg00543.html
> Note that we have observed the following bugs in this area, neither of
> which functionally impact this new build:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=145156
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=145157
> John Graham
> _______________________________________________
> dtp-dev mailing list
> dtp-dev@eclipse.org
> https://dev.eclipse.org/mailman/listinfo/dtp-dev
> dtp-dev@eclipse.org
> dtp-dev@eclipse.org
> dtp-pmc mailing list
> dtp-pmc@eclipse.org
> https://dev.eclipse.org/mailman/listinfo/dtp-pmc
> dtp-dev@eclipse.org
Previous Topic:Is Mysql-4.1 supported ?
Next Topic:bug#145157 - Derby Synonym issue
Current Time: Tue May 13 12:44:24 EDT 2025
Powered by FUDForum. Page generated in 0.03370 seconds
