Home » Language IDEs » C / C++ IDE (CDT) » ASTRewrite - Editing cpp Files with cdt
ASTRewrite - Editing cpp Files with cdt [message #170793] Mon, 05 June 2006 14:15 Go to next message
I'm looking for a class similar to the jdt "ASTRewrite" but for cpp to be
able to
edit cpp files.
this is the jdt ASTRewrite class:
org.eclipse.jdt.core.dom.rewrite.ASTRewrite
see:
http://help.eclipse.org/help31/topic/org.eclipse.jdt.doc.isv /reference/api/org/eclipse/jdt/core/dom/rewrite/ASTRewrite.h tml
I need to manipulate the tree of a cpp file for editing. Is there such a
class for cdt? (otherwise, what should I use?)
Sebastian
Re: ASTRewrite - Editing cpp Files with cdt [message #170918 is a reply to message #170793] Tue, 06 June 2006 13:12 Go to previous message
Currently the CDT DOM is not "rewritable". I think the best you can do
now is to use the location information on the IASTNodes to make your
changes directly back to the file.
You might want to try on the cdt-dev mailing list, there may be others
investigating the rewrite problem.
-Andrew
Sebastian wrote:
> able to
> edit cpp files.
> see:
> Sebastian
Previous Topic:How to indentify a variable-argument function using cdt?
Next Topic:error parsing
Current Time: Fri Jul 18 04:26:47 EDT 2025
Powered by FUDForum. Page generated in 0.05357 seconds
