Error when launching "Run Test Configuration" - Plug-in Development [message #170669] |
Mon, 15 December 2003 17:28 |
Originally posted by: tshilgen.hewitt.com
I've been working on building a plug-in in Eclipse. The launching of the
runtime workspace had been working well for both testing and using the
debugger.I had run the normal "Run Test Configuration" several times
within the Eclipse session without an error. Midway through the session, I
started receiving the following messages in the console:
Unable to find element factory:
org.eclipse.ui.internal.model.ResourceFactory
Unable to restore pagee - cannot instantiate input factory:
Unable to create default perspective - constructor failed.
The following information is from the .log file in the runtime-workspace
directory:
Command-line arguments: -pdelaunch -dev bin -feature org.eclipse.platform
-data d:\eclipse_projects\runtime-workspace -os win32 -ws win32 -arch x86
-nl en_US -configuration
file:d:/eclipse_projects/workspace/.metadata/.plugins/org.ec lipse.pde.core/d__eclipse_projects_runtime-workspace/platfor m.cfg
-install file:D:/eclipse/
!ENTRY org.eclipse.ui 4 4 Dec 15, 2003 16:10:30.115
!MESSAGE Unable to find element factory:
!ENTRY org.eclipse.ui 4 4 Dec 15, 2003 16:10:30.175
!MESSAGE Unable to restore pagee - cannot instantiate input factory:
!ENTRY org.eclipse.ui 4 4 Dec 15, 2003 16:10:30.365
!MESSAGE Unable to create default perspective - constructor failed.
!ENTRY org.eclipse.ui.workbench 4 2 Dec 15, 2003 16:10:30.405
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
!STACK 0
org.eclipse.ui.internal.WorkbenchWindow.restoreState(Workben chWindow.java:1364)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1263)
at org.eclipse.ui.internal.Workbench.access$10(Workbench.java:1 223)
at org.eclipse.ui.internal.Workbench$12.run(Workbench.java:1141 )
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1006)
at org.eclipse.core.runtime.Platform.run(Platform.java:413)
org.eclipse.ui.internal.Workbench.openPreviousWorkbenchState (Workbench.java:1093)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:870)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1373)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at java.lang.reflect.Method.invoke(Native Method)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
FUDForum. Page generated in 0.27632 seconds
