Sending Complex Objects Using SOAP [message #170633] |
Mon, 05 June 2006 16:18  |
Originally posted by: yitzchok.rentmagic.ca
Hi.
I want to use Axis to return a simple class. When i try to generate the
Web Services I get 3 error messages. (Plus the error messege that TomCat 5
does not support Port Listening which is not true and I think I filed a
bug report on it - "IWAB0002I Apache Tomcat v5.5 does not support port
monitoring.")
First I get twice "Error in generating sample JSP" then an error message
window with no text message ("") with [OK/Details] and a lot of details.
Can someone just post code for me that will let me get a Complex Object
back from an Axis server using SOAP?
Using wtp-all-in-one-sdk-R-1.0.2-200604200208-win32.zip
Class code
public class MyClass
public MyClass() {};
protected int integer;
protected String str;
public String getStr() { return str;}
public int getInteger() { return integer;}
public void setStr(String str1) { str =str1;}
public void setInteger(int i) { integer = i;}
The servlet code (Dynamic Web Project)
public class serv {
public MyClass echo (int celsius)
MyClass t = new MyClass();
t.setInteger(celsius);
return t;
The client code:
import java.io.BufferedReader;
import java.io.IOException;
import java.io.InputStreamReader;
import org.ksoap2.*;
import org.ksoap2.serialization.*;
import org.ksoap2.transport.HttpTransportSE;
import org.xmlpull.v1.XmlPullParserException;
public class test {
public static void main(String[] args) throws IOException,
XmlPullParserException {
SoapObject soap = new SoapObject("http://wtp", "echo");
soap.addProperty("celsius", 64);
SoapSerializationEnvelope envelope =
new SoapSerializationEnvelope(SoapEnvelope.VER11);
envelope.bodyOut = soap;
HttpTransportSE ht = new
HttpTransportSE("http://localhost:10477/serve/services/serv");
ht.call("http://schemas.xmlsoap.org/soap/envelope/", envelope);
SoapObject soapIn = (SoapObject)envelope.bodyIn;
System.out.print(soapIn.toString());
Re: Sending Complex Objects Using SOAP [message #170880 is a reply to message #170633] |
Thu, 08 June 2006 13:36  |
Hi Isaac,
It looks like you've found a bug in the sample JSP generation. Could you
please open a bugzilla with the classes you used and the steps to reproduce
the problem? Thanks!
Kathy Chan
"Isaac Good" <yitzchok@rentmagic.ca> wrote in message
news:c258f5ca1b6a42e63dd83812496407fe$1@www.eclipse.org...
> Hi.
> monitoring.")
> Class code
> public class serv {
> return t;
> The client code:
> public class test {
FUDForum. Page generated in 0.06271 seconds
