Home » Eclipse Projects » Plugin Development Environment (PDE) » problem with pde plugin 'export wizard'
problem with pde plugin 'export wizard' [message #16131] Fri, 08 August 2008 02:25 Go to next message
Originally posted by: totolaricot.mac.com
workbench is used to build a client server system with ~70 modules (some
of them shared) including something like this:
A
subset of a library X for client side use
B
complete version of library X for server side use
C
* client/server module that imports the subset of library X via import
packages xxxx.yyyy.zzz
the library can be used on client and server projects
* has A listed as a 'extra classpath' dependency on the Dependencies
screen
* contains 1 sub libraries listed in 'runtime information' on the
build manifest tab
D
screen
* contains 2 sub libraries listed in 'runtime information' on the
build manifest tab
using PDE export bundle wizard, module C can be exported with the export
wizard, while module D cannot built because at compile time, the classes
in xxxx.yyyy.zzzz are not included in the build classpath.
I actually checked the generated build.xml files in both cases and they
are indeed different (C does have an entry for project A while D does
not). While looking at the generated classpath, I was also surprised to
see some things that I did not want there but had been pulled from the
target platform definition.
pde is the most unstable piece of xxxxxxx I have ever seen, not to
mention how pathetic some of its source code looks when compared with
some other projects. the number of problems I have had with things
working then not then again in the last 2 years is absolutely grotesque.
and btw whether or not you like how I say it, or even believe what say
does not change the fact that what I describe is real (and no, I don't
have the time to prepare some nice test cases for some of the
aberrations I have seen - some of them are really blatant - like making
the autogenerated dependencies list differ in two consecutive
recalculations)...
Re: problem with pde plugin 'export wizard' [message #16147 is a reply to message #16131] Fri, 08 August 2008 03:39 Go to previous message
Originally posted by: ekkehard.gentz-software.de
hi L.,
I have also bundles for client / server use, where some things 'overlap',
sometimes the client only uses a part of what the server uses.
in these cases its always good to organize your pde environment well:
some tips from me:
1. use different working sets for server and client
2. have two different target definition files for server and client
then to export from PDE:
use your client (or server) workingset
use your client (or server) PDE Target (simply under preferences - PDE -
target click Load Target, dont forget "chris" checkbox ;-)
now you're sure, PDE onky knows the bundles for client (or server) and
can do the correct export, have correct dependencies etc.
> A
> B
> C
> screen
> * contains 1 sub libraries listed in 'runtime information' on the build
> manifest tab
> D
> screen
> * contains 2 sub libraries listed in 'runtime information' on the build
> manifest tab
L,
if you really think there's something wrong, then you should take the
time to create a testcase and help to find the reason
hey - this is the way open source works ;-)
ekke
> recalculations)...
Re: problem with pde plugin 'export wizard' [message #575997 is a reply to message #16131] Fri, 08 August 2008 03:39 Go to previous message
hi L.,
some tips from me:
> A
> B
> C
> screen
> manifest tab
> D
> screen
> manifest tab
L,
ekke
> recalculations)...
Previous Topic:problem with pde plugin 'export wizard'
Next Topic:Need hints for change editor font size
Current Time: Mon Jul 21 21:07:04 EDT 2025
Powered by FUDForum. Page generated in 0.03063 seconds
