Translation-Error? [message #16096] |
Tue, 25 January 2005 14:25 |
Originally posted by: info.mdsol.de
Hello to anybody,
after installing the german language translation file
(NLpack-eclipse-SDK-3.0.x-win32) into my eclipse SDK3.0.1 i find the
following error messages:
!SESSION Jan 25, 2005 19:44:10.894
eclipse.buildId=M200409161125
java.version=1.5.0_01
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
!ENTRY org.eclipse.ui.intro 4 0 Jan 25, 2005 19:44:10.904
!MESSAGE IntroParser error in line 6, uri
file:/g:/eclipse/plugins/org.eclipse.jdt.nl1_3.0.1/nl/de/new sExtensionContent.xml
Invalid byte 2 of 2-byte UTF-8 sequence.
!STACK 0
org.xml.sax.SAXParseException: Invalid byte 2 of 2-byte UTF-8 sequence.
at com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(U nknown
Source)
com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl. parse(Unknown
Source)
at javax.xml.parsers.DocumentBuilder.parse(Unknown Source)
org.eclipse.ui.internal.intro.impl.model.loader.IntroContent Parser.parse(IntroContentParser.java:61)
org.eclipse.ui.internal.intro.impl.model.loader.IntroContent Parser. <init>(IntroContentParser.java:38)
org.eclipse.ui.internal.intro.impl.model.IntroModelRoot.load DOM(IntroModelRoot.java:578)
org.eclipse.ui.internal.intro.impl.model.IntroModelRoot.reso lveConfigExtensions(IntroModelRoot.java:261)
org.eclipse.ui.internal.intro.impl.model.IntroModelRoot.reso lveChildren(IntroModelRoot.java:186)
org.eclipse.ui.internal.intro.impl.model.AbstractIntroContai ner.getChildren(AbstractIntroContainer.java:66)
org.eclipse.ui.internal.intro.impl.model.IntroModelRoot.load Model(IntroModelRoot.java:116)
org.eclipse.ui.internal.intro.impl.model.loader.BaseExtensio nPointManager.loadModel(BaseExtensionPointManager.java:78)
org.eclipse.ui.internal.intro.impl.model.loader.ExtensionPoi ntManager.loadCurrentModel(ExtensionPointManager.java:60)
org.eclipse.ui.internal.intro.impl.model.loader.ExtensionPoi ntManager.getCurrentModel(ExtensionPointManager.java:72)
org.eclipse.ui.intro.config.CustomizableIntroPart.init(Custo mizableIntroPart.java:124)
org.eclipse.ui.internal.ViewIntroAdapterPart.init(ViewIntroA dapterPart.java:142)
at org.eclipse.ui.internal.ViewFactory$1.run(ViewFactory.java:3 29)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:616)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
org.eclipse.ui.internal.ViewFactory.busyRestoreView(ViewFact ory.java:273)
at org.eclipse.ui.internal.ViewFactory$2.run(ViewFactory.java:5 30)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.ui.internal.ViewFactory.restoreView(ViewFactory. java:528)
at org.eclipse.ui.internal.Perspective.showView(Perspective.jav a:1593)
org.eclipse.ui.internal.WorkbenchPage.busyShowView(Workbench Page.java:773)
at org.eclipse.ui.internal.WorkbenchPage.access$9(WorkbenchPage .java:753)
at org.eclipse.ui.internal.WorkbenchPage$13.run(WorkbenchPage.j ava:3051)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage .java:3048)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage .java:3028)
org.eclipse.ui.internal.WorkbenchIntroManager.createIntro(Wo rkbenchIntroManager.java:136)
org.eclipse.ui.internal.WorkbenchIntroManager.showIntro(Work benchIntroManager.java:85)
org.eclipse.ui.internal.WorkbenchWindow.restoreState(Workben chWindow.java:1413)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1224)
at org.eclipse.ui.internal.Workbench.access$10(Workbench.java:1 185)
at org.eclipse.ui.internal.Workbench$13.run(Workbench.java:1096 )
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1029)
org.eclipse.ui.internal.WorkbenchConfigurer.restoreState(Wor kbenchConfigurer.java:167)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:652)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:819)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1325)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
!SESSION Jan 25, 2005 19:47:07.949
Before i put the files in there was not any error-message written in the
error-message window.
I get the same results with the java jdk1.4.2_06.
Is this a general problem with the german eclipse translation or with the
jdk?
Michael
FUDForum. Page generated in 0.08907 seconds
