Hardware Requirement [message #170011] |
Fri, 08 September 2006 08:06 |
Originally posted by: landolini.yahoo.it
Sorry,I don't find hardware requirement for Eclipse.
I've installed it and sometimes locks the system and many disk
error are arised....
I've 320 MB RAM and PC speed 700 MHz .
Thanks.
Re: Hardware Requirement [message #170534 is a reply to message #170011] |
Tue, 12 September 2006 14:43 |
I don't know if there are any "official" hardware requirements, but
yours sounds like it is too weak. By the time the operating system
loads, your RAM will be down below 256MB, which is generally the minimum
setting used for running Eclipse. And 700MHz is going to be painful in
many areas.
Hope this helps,
Eric
Re: Hardware Requirement [message #170591 is a reply to message #170011] |
Tue, 12 September 2006 16:50 |
Originally posted by: ns_dkerber.ns_WarrenRogersAssociates.com
In article <b2e4a62def6a5d9ba6bcfe1f50cd9249$1@www.eclipse.org>,
landolini@yahoo.it says...
> Thanks.
That's a pretty low spec for running Eclipse, but it still shouldn't
throw disk errors. Have you done a scandisk recently? I would say that
with that cpu, you would need at LEAST 512MB; more if you have other
apps running in the background.
Remove the ns_ from if replying by e-mail (but keep posts in the
newsgroups if possible).
FUDForum. Page generated in 0.07597 seconds
