Home » Language IDEs » Java Development Tools (JDT) » finally block does not complete normally
finally block does not complete normally [message #169915] Fri, 23 July 2004 18:06 Go to next message
I upgraded to Eclipse 3.0 this week and am now getting a problem warning
on all of my finally blocks in all my projects. When I check to see what
Eclipse suggests for to fix this, I get "No corrections available". As
fas as I know there is nothing wrong with my finally blocks. I've done an
internet and Eclipse search and found nothing. Is anyone else getting
these errors? Does anyone know why they're being generated? Maybe it's a
bug in Eclispe?
Thanks in advance,
Shelli
Re: finally block does not complete normally [message #169925 is a reply to message #169915] Fri, 23 July 2004 18:10 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Please append your finally block so that we can see it.
Thanks, Rich Kulp
Re: finally block does not complete normally [message #169933 is a reply to message #169915] Fri, 23 July 2004 19:30 Go to previous messageGo to next message
Originally posted by: olivier_thomannNO.ca.ibm.comSPAM
Le Fri, 23 Jul 2004 22:06:29 +0000 (UTC), shelli.orton@wmode.com
>bug in Eclispe?
Your finally block might contain a return statement. If this is the
case, the finally block doesn't complete normally. Normally means that
you exit the block at the end of the block without going through a
return or a throw statement.
Paste one of your finally block and we can tell you for sure what is
wrong.
Because a finally block is executed even if there is an uncaught
exception in the try block, a finally block that doesn't complete
normally is a potential problem or source of bugs.
For example, if you have something like this:
class Example {
static void foo() {
throw new RuntimeException();
try {
foo();
} finally {
return;
Do you think that the exception will be thrown after the finally block
is executed? The answer is no. Because you have a return statement,
the runtime exception is "eaten".
That example will throw the runtime exception:
class Example {
static void foo() {
try {
foo();
} finally {
This is why we have such warning. Note this is only a warning. There
is nothing wrong doing that. It could however hide a bug.
Hope this help,
Olivier
Re: finally block does not complete normally [message #170030 is a reply to message #169915] Mon, 26 July 2004 11:55 Go to previous messageGo to next message
Originally posted by: bob.news.gmx.net
"Shelli" <shelli.orton@wmode.com> schrieb im Newsbeitrag
news:cds255$efu$1@eclipse.org...
what
an
a
> bug in Eclispe?
You probably exit a finally block via a return or via a possible
exception. This is often the case if you close an InputStream or an
OutputStream in a finally without catching the IOException. You should
always rewrite those finally blocks to
finally {
try {
stream.close();
catch ( IOException ignore ) {
robert
Re: finally block does not complete normally [message #170077 is a reply to message #169933] Mon, 26 July 2004 16:17 Go to previous messageGo to next message
Aha!
Yes, all the finally blocks that are getting the warning have the return
statement in them. I'll have to take a closer look and make sure there's
no potential for hidden bugs and make changes as necessary.
Thank you so much!
Shelli
> >bug in Eclispe?
> wrong.
> class Example {
> static void foo() {
> public static void main(String[] args) {
> try {
> foo();
> } finally {
> return;
> class Example {
> static void foo() {
> try {
> foo();
> } finally {
> Hope this help,
> Olivier
Re: finally block does not complete normally [message #170083 is a reply to message #170077] Mon, 26 July 2004 16:34 Go to previous messageGo to next message
Le Mon, 26 Jul 2004 20:17:42 +0000 (UTC), shelli.orton@wmode.com
(Shelli) a écrit :
>Aha!
The return statement prevents any unchecked exception from being
rethrown after the code in the finally block has been executed. I
would say this is a bad practice as it can hide any runtime exception
like NullPointerException :-).
If you are sure that you want to return once the finally is executed,
then simply put the return statement immediately after the
tr/catch/finally construct and not inside the finally block.
Olivier
Re: finally block does not complete normally [message #170255 is a reply to message #170083] Tue, 27 July 2004 07:45 Go to previous messageGo to next message
"Olivier Thomann" <olivier_thomannNO@ca.ibm.comSPAM> schrieb im
Newsbeitrag news:8gqag01eelsuotat0ff94djlg1u9bml28p@4ax.com...
> (Shelli) a écrit :
> >Aha!
return
there's
I prefer to put the return into the try block. Why? Because you then get
soon warned that you forgot to handle exceptions properly if you do:
// init
try {
// do stuff
return 1;
catch ( Exception ex ) {
// unhandled yet
finally {
// cleanup
This will raise a compiler error. This will not:
// init
try {
// do stuff
// unhandled yet
finally {
// cleanup
// accidentally return the value that
// was intended to be the "ok" value:
return 1;
The finally block is executed in both cases.
robert
Re: finally block does not complete normally [message #170278 is a reply to message #170255] Tue, 27 July 2004 10:28 Go to previous message
Le Tue, 27 Jul 2004 13:45:07 +0200, "Robert Klemme" <bob.news@gmx.net>
Sure. My point was simply to say that a return statement in a finally
block might have undesired side effects :-).
Olivier
Previous Topic:Where does the PackageExplorerPart add basic actions
Next Topic:Builders do not follow displayed order
Current Time: Sat Sep 06 16:01:41 EDT 2025
Powered by FUDForum. Page generated in 0.34019 seconds
