Home » Modeling » GMF (Graphical Modeling Framework) » reason for workaround
reason for workaround [message #16074] Fri, 11 August 2006 14:30
Originally posted by: vcciubot.uwaterloo.ca
Hi all,
I'm looking at the auto-generated code that adds the figure of a
TextCompartmentEditPart to its parent.
The code in the parent EditPart creates a WrapLabel and adds it to
its contentPane.
It then overrides
protected boolean addFixedChild(EditPart childEditPart)
to intercept when the figure of the child would be added and it
replaces the child's figure by the parent created WrapLabel.
If I remove this code, the child figure never shows up.
thanks for you help
vlad
Previous Topic:Nesting a GMF FileDiagramEditor inside a org.eclipse.ui.part.MultiPageEditorPart
Next Topic:Are All Compartment Based on ScrollPane
Current Time: Mon Jul 21 21:04:36 EDT 2025
Powered by FUDForum. Page generated in 0.24813 seconds
