Command safety tip and debugging tip [message #169702] |
Fri, 25 February 2005 09:46  |
My particular GEF application has very complex and coordinated EditPolicy's.
For example, on a LayoutEditPolicy's getAddCommand(), I have to dispatch
other Requests and accumulate their resulting Commands. To be more
concrete: when a child figure is moved from one figure to another there may
be a set of other Requests that get fired off to perform functions such as
changing the look of the child based on the new parent and adding and
removing other children which provide context.
On following the advice of the guru's of the group I modelled my application
after the logic example. Unfortunately, the paradigm presented therein is
not suitable for my situation for one primary reason: when "creating"
Commands (I put that in quotes only to emphasize the fact that I'm talking
about both construction and the calling of the appropriate setters) some of
the elements may change at execution time due to other Commands that have
been called.
For example:
LogicFlowEditPolicy.createAddCommand(...):
AddCommand command = new AddCommand();
command.setChild((LogicSubpart)child.getModel());
command.setParent((LogicFlowContainer)getHost().getModel());
int index = getHost().getChildren().indexOf(after);
command.setIndex(index);
return command;
In my particular application the parent *cannot* be set when "creating" the
command since the component may be reparented (by other Commands) between
the time that the Command is "created" and added to the CommandStack and the
time that it is executed. Only on Command.execute() can the parent be
retrieved from the child and be stored. (Note that the parent *must* be
stored on Command.execute() for Command.undo() to function correctly. If
Command.undo() was to retrieve the parent when it was called then that would
obviously be the incorrect parent.)
Tracking down this situation was non-trival since there are two different
factors that must be considered: when / where the Command was "created" and
when / where the Command was executed. In my case, the "created" part was
the most important. But as most of you know, the various EditPolicy methods
are called quite frequently and it's *very* *very* *very* hard to determine
which Command "create" is the one that is actually added to the CommandStack
and executed. (If you don't already know, the various EditPolicy methods
are also called to make sure that you can do something such as when
components are selected ComponentEditPolicy.createDeleteCommand(..) is
called to ensure that the component is deletable (i.e. Command.canExecute()
is called and Command.execute() is not called). In this case the Command
retrieved from ComponentEditPolicy.createDeleteCommand(..) is never actually
exectued. (The Command from ComponentEditPolicy.createDeleteCommand(..) is
only exectued when the DeleteAction occurs.) This can be very confusing the
first time you stumble across it.)
To get around this problem of knowing which Command is actually executed and
where it was "created" from, I used the following trick:
In the constructor of my Command I did the following:
public SomeConcreteCommand() {
this.constructionException = new Exception();
(where "constructionException" is declared as "private Exception
constructionException"). Then in execute() I did the following:
public void execute() {
constructionException.printStackTrace(...);
What this does is allow me to see the stacktrace of where the Command was
"created" -only- when it is executed.
(I should mention of completeness that this technique for storing an
Exception() is *very* heavy weight and will affect performance. This is
only suitable for development / debugging and should not be kept for
production code.)
In summary: There may be cases in which some elements of a Command cannot
be set when "created". These elements can be retrieved and stored when
Command.execute() is called. To facilitate debugging Commands it may be
useful to store an Exception created on construction of the Command and
display the stacktrace of the Exception when Command.execute() is called.
To help with the fomatting of this posting I have made it available on my
blog at:
http://www.realityinteractive.com/rgrzywinski/archives/00017 8.html
I hope this has been helpful.
Rob Grzywinski
Re: Command safety tip and debugging tip [message #169932 is a reply to message #169762] |
Mon, 28 February 2005 08:41  |
> Why not put a breakpoint in performCreation or handleButtonUp or something
> in the tool which is executing the command?
Primarily because using the debugger for handling full-cycle mouse events
(press, drag (across multiple EditParts), release) is an enormous PITA. I
was simply providing an alternate tip for debugging. I apologize if I
neglected to mention the obvious alternative techniques in my write up.
Rob Grzywinski
FUDForum. Page generated in 0.26646 seconds
