Getting an IAdaptable from an EObject [message #169473] |
Wed, 23 January 2008 07:14  |
Originally posted by: trommas.yahoo.com
From a new CreateViewRequest it would be:
// Get the Adapter to a newly created object
IAdaptable shapeViewAdapter = (IAdaptable) ((List) shapeRequest
..getNewObject()).get(0);
But I need the IAdaptable from an existing object. (ex: ClassNode a;)
Any Ideas?
Tomas Zijdemans
Re: Getting an IAdaptable from an EObject [message #169676 is a reply to message #169496] |
Thu, 24 January 2008 09:33   |
Christian W. Damus wrote:
> Hi, Tomas,
> EObjects aren't IAdaptable, so I don't know that this question really makes
> sense.
> There is an EObjectAdapter class that wraps an EObject for IAdaptable-ness,
> but it's up to you still to implement the required adaptations.
You are absolutely correct, it didn't make sense. What I meant was how
do I get an IAdaptable for a specific editpart?
What I'm trying to do is to create a link to an existing node - the link
creation needs two IAdaptables (source and target).
ICommand createLinkCmd = new DeferredCreateConnectionViewAndElementCommand(
connectionRequest, new EObjectAdapter((EObject) source
..getModel()), target, source.getViewer());
Thanks for helping,
Tomas Zijdemans
> HTH,
> Christian
>> Any Ideas?
>> Tomas Zijdemans
Re: Getting an IAdaptable from an EObject [message #169691 is a reply to message #169676] |
Thu, 24 January 2008 10:01   |
It seems to be solved. Just throwing the editpart to IAdaptable seems to
work :) Doh!
Tomas Zijdemans
>> Hi, Tomas,
>> makes
>> sense.
>> IAdaptable-ness,
> Thanks for helping,
> Tomas Zijdemans
>> HTH,
>> Christian
>>> Any Ideas?
>>> Tomas Zijdemans
Re: Getting an IAdaptable from an EObject [message #169699 is a reply to message #169691] |
Thu, 24 January 2008 10:04  |
Hi, Tomas,
Yes, all EditParts in GEF are adaptable (EditPart implements IAdaptable).
I'm glad it worked out!
Christian
> work :) Doh!
> Cheers,
> Tomas Zijdemans
-----8<-----
FUDForum. Page generated in 0.24974 seconds
