Compilation!!!!!!!!!!!!!!! [message #169436] |
Tue, 05 September 2006 08:59 |
Originally posted by: landolini.yahoo.it
It's everything too much difficult for me !
I've read the content help ,made search in the forum...
but I've not realized if Eclipse can compile a source !!!?
I've done an project entry,a package entry,a class ,...now I
don't see how compile it (have I to use javac command in a
command line ?) .
Netbeans it very very easier .what have I to do ?
Thanks.
Re: Compilation!!!!!!!!!!!!!!! [message #169452 is a reply to message #169436] |
Tue, 05 September 2006 09:06 |
Originally posted by: nospam.home.com
"lando" <landolini@yahoo.it> wrote in message
news:b2977e2895138cf6a2675fe89d5c0a2e$1@www.eclipse.org...
> I've done an project entry,a package entry,a class ,...now I don't see how
> compile it (have I to use javac command in a command line ?) .
> Thanks.
AFAIK, if you are using the default settings, Eclipse will build the project
every time you save a source file. You can change this behaviour by going
to Window->Preferences->General->Workspace and untick "Build automatically".
This will then add build options to the Project menu.
HTH,
Wes
Re: Compilation!!!!!!!!!!!!!!! [message #169495 is a reply to message #169436] |
Tue, 05 September 2006 12:32 |
Jeff Myers Messages: 489 Registered: July 2009 |
> how compile it (have I to use javac command in a command line ?) .
> Thanks.
By default, your Java source is compiled every time your source code is
saved. The resulting classes are not shown in the Package Explorer
view, but will show in the Navigator view (Window->Show
View->Navigator). As noted previously, you can manually invoke a build
by turning off the Build Automatically option, but that causes some of
the Java editor functions to stop working. The normal way to use Eclipse
is to keep auto-build turned on.
Hope this helps,
- Jeff
FUDForum. Page generated in 0.08638 seconds
