silent appending to an IFile [message #169223] |
Thu, 11 December 2003 10:07  |
I have an action that triggers a very long running operation in a new thread
that continously dumps results to an IFile using the appendContents method.
The problem is that when this happens the whole project tree flashes and
refreshes, and it is 5 times slower than writing directly to a java.io.File.
Presumably this is because of the events that are triggered and the
corresponding listeners. Is there a mechanism for silently appending to a
file, or any other method that could stop the triggering of these events? I
don't notice any such effects when the java files are compiled to class
files by the jdt project, do they have some trick for doing this?
Tony
Tony Poppleton
Evolutionary Scientist
Codefarm Software Limited
Sussex Innovation Centre
Science Park Square, Falmer, Brighton, BN1 9SB, UK
tel: +44 (0)1273 704417 fax: +44 (0)1273 704499
http://www.codefarm.com/
Codefarm is a leading provider of optimization software, specialising
in distributed and evolutionary computing technologies.
Re: silent appending to an IFile [message #172021 is a reply to message #169223] |
Thu, 18 December 2003 12:28  |
Originally posted by: John_Arthorne.oti.com_
You can batch a set of changes to avoid resource change events using
IWorkspace.run(IWorkspaceRunnable). In Eclipse 3.0, you can also make
your background activity a subclass of WorkspaceJob. A WorkspaceJob
will batch its changes automatically. See
org.eclipse.core.runtime.jobs.Job, and
org.eclipse.core.resources.WorkspaceJob for more details.
Tony wrote:
> Hello,
> Tony
> Tony Poppleton
FUDForum. Page generated in 0.05224 seconds
